Lead based paint usually isn't electrically conductive, it is however electro-magnetically conductive. Even electrically isolated the sheer amount of conductive molecular elements spread across space are equivalent to an RF short circuit. As frequency increases the dielectric becomes less and less an issue.
could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." Last edited by Sceadwian; 3rd July 2008 at 03:48 AM. |
This might be the time to build a Faraday workshop! Just kidding as it is overkill for hobby use.
But it is what I use at work when repairing sensitive instruments. I'd go crazy chasing ghosts otherwise. See if your scope probes came with some little spring like pieces which fit over the ground ring on the tip. You'll have to pull off the hook clip to see the ground ring near the probe tip. These are used to provide a shorter ground path when working with RF circuits.
--- The days of the digital watch are numbered. --- Last edited by kchriste; 3rd July 2008 at 04:42 AM. |
Yeah, I've used those before, we called them 'pigtails' at the last place I worked (doing PWM amplifier stuff and having to look at edges). I'll see if the probes came with any.
Interesting fact, I looped the wire around itself several times and by varying the orientation was able to make the noise go from >60mv pk-pk to 18mv pk-pk. I still want to try it in other locations to make sure there's not some issue with the scope and noise, it being a rather expensive purchase for me. But I am feeling a little bit relieved. Still, 12mv pk-pk at Dad's office building seemed like a little more than I expected. If anyone can tell, I'm real concerned about noise in the work that I do |
I imagine that the noise level has such a low current, that when the probe is actually on a circuit under test, the signal will vanish.
I had the ground clip on the probe tip though...
Any other comments?
The ground clip has x length which acts like an inductor at 200 MHz. Also you may notice this more now because your scope input has such a wide BW. I am really quite envious.
Check think link, it discusses the issue. http://www.cs.umbc.edu/~plusquel/650...surements1.pdf Take note of page 9 Last edited by Mikebits; 4th July 2008 at 08:19 PM. |
| Tektronix 2246 Scope Problem | Mendoza | General Electronics Chat | 8 | 23rd March 2008 04:38 PM |
| MADELL O-Scope question | Ambient | General Electronics Chat | 2 | 24th March 2007 04:01 PM |
| rookie scope question | chancecasey | General Electronics Chat | 26 | 25th January 2007 04:04 AM |
| Quick question/problem on a BCD counter. | czwalga | Electronic Projects Design/Ideas/Reviews | 4 | 13th August 2006 11:27 PM |
| HV scope probe question | Oznog | General Electronics Chat | 1 | 13th October 2005 11:56 PM |
