Hi to all,
I am in the process of building an ESR meter from here Capacitor ESR Meter and just getting a bit puzzled about a couple of things. Firstly as I have not had a lot to do with MOSfets I am worried that I can't tell which is the Source and Drain on the BS170 at the top left. Also I am puzzled what the Backlight and Credits part does, its below the right hand side of the LCD in the schematic, does the circuit imply that a switch would short RC0 and RC1 and connect them to RB2 when the switch is made? If it does can anyone explain why? And would it need a latching switch? Also I am assuming that the on and off switches are momentary push to make types, and as there is no other means of disconnecting the battery I wondered if it would be continuously pulling a small amount of current? Maybe it would be better to add a further switch directly after the battery, maybe a toggle or slider? Any thoughts? Thanks in advance for any help.................Al
Founder member of the Campaign to do Something about the none existant word "Somethink" |
(permalink) | |||
But you could simplify the circuit by putting a toggle switch in the B+ line and eliminating the BS170, the 1n4148's, the 100nf caps, and some resistors if you wanted to.
--- The days of the digital watch are numbered. --- Last edited by kchriste; 30th June 2008 at 12:31 AM. |
I doubt the connection of LCD pin 3 to pin1. It would be dark squares across the display. The contrast pin needs to be treated properly. I don't think that this could be the final version of the project.
Regards, Sarma. |
Hi guys,
Thanks for all the info, I have some more of it sorted now due to the advice. Also I have substituted a 2n7000 for the BS170 as it seemed close in spec! Is it OK? Thanks for the orientation Ron. Thanks kchriste for the tips, would the double pole switch be momentary too? Since I already etched the board I will try to stick with the original plan, but I have another small problem, I can't see where the OFF switch should go on the silkscreen! Can any of you show me, I have sussed the ON switch but can't find the OFF pins! Also if there is an obvious ground pin I must have missed it, the pos has been brought out to the bottom right, but where is the ground? Also I have taken on board the contrast suggestion and will fit a pot into the design, well spotted, thanks Sarma! Also did anyone notice that the orientation of the two 1N4148 diodes is different in the silk to the photo, though it doesn't seem to matter! And again thanks for the replies guys
Founder member of the Campaign to do Something about the none existant word "Somethink" Last edited by bigal_scorpio; 30th June 2008 at 10:45 PM. Reason: forgot something |
(permalink) | ||
--- The days of the digital watch are numbered. --- |
[quote=kchriste;323913]I don't remember a double pole switch, but if you meant the "toggle switch" I mentioned, then no, make it latching.
Hi kchriste, No I didn't mean the toggle switch. I mean the switch under the right of the LCD panel with Credits and Backlight on it. If its a momentary then I am struggling to find one that has the two poles necessary to not permanantly short RC0 and RC1! On the other hand I have plenty of latching double pole switches. Any ideas? Thanks................Al
[quote=bigal_scorpio;323989]
All the 'credits' switch does is display the author/designer names in a sequence of 4 labels. Not required IMHO. The LCD backlight is a latching switch, it seems a waste of two PIC pins to enable the backlight via the PIC.
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 1st July 2008 at 11:04 AM. |
Thanks Eric,
On your advice a I will not bother with the credits and put the backlight on a seperate switch! BTW did you notice any other flaws in the schematic to copper transition, kchriste and others seem to be a little concerned about some parts, do you think it will work? Thanks again Eric...........Al
I'll have a quick look. Ran the program in Oshonsoft Sim, see the two LCD shots. The 'credits' is what you get with that switched on, the 'esr' is what you see at power ON.
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 7th July 2008 at 11:25 AM. |
hi Al,
My first thoughts on the schematic is that it was drawn on the back of a 'fag packet'. Its laid out on the sch in a confusing hard to follow way. The program ran first time in the OS Sim, which is promising. He has also gone to the trouble of defining all the PIC registers in the program, why.?? The designer seems to gone to a lot of trouble to ensure all the PIC pins are used.? eg: Used all 8 LCD data lines. Driving the backlight via the PIC and a transistor. Sw to select the credits display. etc. As pointed out by Sarma, the LCD Vo contrast control. Why he has got a 'fussy' power ON/OFF control is puzzling.? I would recommend that you configure this circuit on a project board before considering an artwork. Its not possible to say whether it will work or not. IMHO the circuit to the left of the PIC [dwg] could be simplified.
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 1st July 2008 at 11:56 AM. |
Hi Eric,
Well thanks to you I know the circuit should work! But I am getting deeper and deeper all the time with the board itself! Each time I trace where a component goes I find something strange eg. when I was going to place the BS170, and found that the Gate seems to come from the pos supply through the 1N4007 instead of the drain. So if he has cocked up on that maybe other parts pins are wrong on the board? Also I seem to have struck a wall in the number of transistors, 5 on the schematic and mysteriously 6 on the layout, so I may be at the end of this project now! I wish I hadn't etched the board already, and it was my last biggish piece of copper too! Any help appreciated mate, and thanks so far. Regards...............Al
Ive had a further look and there are big discrepancies twixt the schematic and pcb layout.... I think it maybe another 'doorstop' project.! Can you sketch out a circuit diagram from the pcb artwork layout, so that we can compare the differences.. its difficult going back and forth between the pcb and sch.
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ |
Hello again Eric,
I am still messing with the circuit, having now drawn my own circuit from the schematic. Do you have any info on the LM339 that is reliable, as I have noticed that the LM339 was getting a bit warm! Then I looked further into the schematic wondering if I should ground unused pins, and the Datasheet says yes, but what I also noticed is that the schematic says pin 12 is V+ and pin 3 is Gnd, however the datasheet says 3 is V+ and 12 is Gnd! So my question is which is correct, after all you did a simulation that worked, so I am now confused? Would your sim software have shown the reversed pins error? Would there be any damage to the LM339 due to reversed polarity, as I only have the one More to the point can you confirm through use which is the correct pinout for V+ and Gnd? Thanks for looking at my latest installment of the ESR meter of doom! Regards.............Al
| Schematic Reading Help | tazman2087 | General Electronics Chat | 38 | 2nd July 2008 01:47 AM |
| help reading a schematic | leonrayo | General Electronics Chat | 5 | 13th May 2008 01:38 PM |
| Reading Volvo cooling fan schematic | jamyers | General Electronics Chat | 6 | 8th January 2008 05:31 PM |
| Need some help reading a schematic | compunerdy | Electronic Projects Design/Ideas/Reviews | 14 | 29th October 2007 02:24 PM |
| reading a schematic | mike_ss | General Electronics Chat | 6 | 27th December 2005 03:21 AM |
