Old 28th June 2008, 02:32 PM   (permalink)
Thanks Roff but no can do. Firstly because the goal was to not interfere with the stock electronics making this a "plug and play" type add-on and secondly, and more importantly, because I would have no idea where to start on the stock electronics to achieve such a result.
For the time being I am going to solder up what I have. Might try again at a later time with a H-bridge driver.
Thanks again
DamoRC is offline   Reply With Quote
Old 28th June 2008, 02:59 PM   (permalink)
Thanks again
The pullups could be added to the A and B inputs of your new circuit. Don't they connect directly to the outputs of the stock H-bridge?
Ron
Roff is offline   Reply With Quote
Old 28th June 2008, 05:29 PM   (permalink)
Yes they do.
Pulling both inputs high as the default condition of the circuit would mean the coast condition would be two highs. Let me brood on this for a while to see if I could make that work. Thanks for the suggestion.
Old 28th June 2008, 07:38 PM   (permalink)
Yes they do.
If you do a truth table, you'll see that the logic is really simple. If you need help with the truth table, let us know.
Ron
Old 28th June 2008, 08:25 PM   (permalink)
When you say "truth table" do you mean:
A high B high - coast
A high B low - forward
A low B high - reverse
A low B low - brake
Old 29th June 2008, 12:24 AM   (permalink)
A low B low - brake
I mean the complete truth table to control each individual MOSFET, as below.
Ron
Old 30th June 2008, 04:42 PM   (permalink)
Okay - so what I need to do now is come up with a set of logical operations that both A and B go through to deliver the desired outputs at W, X, Y and Z. I'll get back when I have the answer figured out.
Cheers.
Old 30th June 2008, 05:47 PM   (permalink)
Cheers.
That's correct, and the logic functions are really simple. Don't waste too much time on them unless you want the learning experience. We can post them here.
PS The simplest way is probably to use gates in the CD4000 logic family. Keep in mind that you will have to follow each one with a level translator, which will generally also be a logical inverter.
Ron
Old 4th July 2008, 08:15 PM   (permalink)
Roff - thanks. For now I am going to go without a brake. I completed the circuit (version 2) and thus far it seems to work fine.
I will revisit the brake function at a later date and learn smething about the logic family that you have suggested.
Again thanks for all of your help
Or Gate Circuit ldmbgh Electronic Projects Design/Ideas/Reviews 6 10th July 2007 10:11 PM
Minimising this Circuit. Inputs Needed Electro-freak Electronic Projects Design/Ideas/Reviews 4 25th April 2007 07:42 AM
electric fencing circuit built around 12V shridhar_kasat Electronic Projects Design/Ideas/Reviews 3 21st March 2007 04:12 PM
Digital inputs and PFI trigger inputs on NI PCI 6259 tigercotter Electronic Projects Design/Ideas/Reviews 1 2nd March 2005 04:58 PM
Quad 2-input NOR-gate with schmitt trigger inputs... Exo Datasheet/Parts Requests 7 22nd July 2004 03:29 PM
