i need some circuit diagrams to invert the 12v from my car socket to a 110/240vAC output. very low power will do, only 30-40VA needed. i just need to charge my digicam batteries(AA/AAA) while on the run. Battery charger specifications: input: 100-240 V AC, 50/60 Hz, 16-21 VA thanks in advance. | |
Hi 555addict, Here are a couple: http://www.discovercircuits.com/C/co-dctoac.htm It may be simpler and cheaper to find the output voltage of your charger and build a regulator circuit to run directly from the car's 12 volt system.
__________________ I know I learned everything at least once, now where did I write it down? | |
| | #3 | |
some reasons for not using the output voltage: 1. output : 1.2 V, 1275mA !!!! this one is used to charge 2100mAh batteries. 2. it's got internal circuitry which controls the charging period, i do not want to bypass that. NiMH batteries are very costly. | ||
