When creating filters, i come up with weird resistor values - i guess that's pretty common. Is there an online website or a program that shows you the combination of commercially available resistors u can use in parallel or series to achieve the resistance u need?
thanks in advance |
It's easy to write yourself a little computer program that does this for you, I did one years ago under DOS - don't know where it's gone now?.
Store the preferred values in an array, then use a simple loop to parallel all the different values and check the percentage of error for each combination against your required target value, then display the best result. |
can u expand on this part? btw i have no experience programming or compiling code under dos.. oh well, i got ubuntu to solve that problem now...
what would be the logic behind creating a combination of series and parallel connections to achieve perfect results though? create connection in series, get result very close (but less) to the value you are trying to achieve, then connect a parallel connection to achieve the smaller value to get close to the perfect total? btw where can i obtain a list of commonly commercially available resistor values? |
(permalink) | |||
E12 is 1 1.2 1.5 1.8 2.2 2.7 3.3 3.9 4.7 5.6 6.8 8.2 |
Here are two small programs I did in Visual Basic to calculate 1% resistor values and to optimize a parallel combination for a desired resistor value Advertisement
Carl |
I tried to upload a superb electronic calculating software just only 1.25mB.But it takes hell of a time to upload them.So I coudn't upload it.
Here is another good one. Info about MiscEl |
whats the name of the software you were tryıng to upload? uploading 1.25 mb takes long time..? hello 80's??
Did you visit the link that I posted? I think it is what you need.
thanks for your contribution |
actually looks pretty damn nice with that 555 timer based oscillator configuration
I wish people would release the source code to these programs - they're not selling them so there's no reason not to.
Another thing that people forget is component tollerences reduce the accuracy more when you start connecting them in series or parallel. For example connect two 5% 100k resistors in parallel for 50k and you end up with 50k +-10% which is The E12 series has an accuracy of 10% which is good enough for most applications and in the case of the example above you're no better of using two 100k resistors than you are using one 47k resistor. Connecting resistors in series or parallel is handy when you use a precision resistor for most of the resistance and a less accurate resistor to get that little bit closer to the desired value. For example, suppose you want 50k. You have a 0.5% resistor in the e48 value of 48.7k, you can easily get near enough exactly 50k by adding a cheap 5% 1.2k resistor in series.
Worst cases for two 100K 5% resistors: 105K (+5%) paralled with 105K (+5%) = 52.5K (50K +5%) 95K (-5%) paralled with 95K (-5%) = 47.5K (50K -5%) 105K (+5%) paralled with 95K (-5%) = 49.875K (50K -0.2%) Ken
"To invent, you need a good imagination and a pile of junk." Thomas A. Edison (1847 - 1931) |
Yes he was, completely wrong!
Tolerence remains the same, and (assuming the resistors are from different batches) is more likely to be improved than not. |
I agree with Nigel's statement from a statistical standpoint. But to follow up on it a little more, does anyone know how the "tolerance" for passive components is defined?
That is, is the "+/-5%" (etc.) related to a coefficient of variation (i.e., the standard deviation divided by the mean as a percentage), with the limit set at 2, 3 or some other number of standard deviations, or is it more like a manufacturing tolerance for which one would expect all (>99.999%) of the components to fall within? Apropos his comment, "assuming the resistors are from different batches," I have noticed that within a single apparent lot (e.g., a section of cut tape), the values are pretty close to each other, but not randomly distributed with respect to the expected mean. That observation is just anecdotal, but does relate to how one would calculate the expected error for a combination of components from the same lot. John Last edited by jpanhalt; 6th July 2008 at 11:13 AM. |
As you have found, resistors from the same batch are normally very close in value, but can obviously be anywhere within the stated tolerence. If you need specific accuracy, then use better tolerence resistors, or handpick them from a number of different batches.
Certainly though in recent years, 5% resistors are generally much better than 5%, presumably manufacturing techniques have improved?. |
| custom usb keyboard | kutalinelucas | Electronic Projects Design/Ideas/Reviews | 6 | 21st November 2007 02:24 AM |
| Custom ICs | Souper man | Electronic Projects Design/Ideas/Reviews | 3 | 13th July 2007 07:20 PM |
| Custom Cases | bh00 | Electronic Projects Design/Ideas/Reviews | 3 | 20th March 2007 06:40 PM |
| Custom enclosures | DragonMaster0121 | Electronic Projects Design/Ideas/Reviews | 1 | 27th August 2005 11:12 PM |
| Custom IR to RF and RF to IR... Please help | jcloninger | Electronic Projects Design/Ideas/Reviews | 6 | 23rd June 2005 12:55 AM |
