| If its in an airtight bag the crystals will last a very long time. In liquid state it has a much shorter shelf life. A datasheet I have say unopened Sodium Persulphate has a shelf life of 3 years while opened Sodium Persulphate has a shelf life of 1 month. I've also got a datasheet to say that Ammonium Persulphate has a shelf life of 1 year in crystal form. | |
| My 1KG bottle is over a year old, maybe closer to two. It still works. I do not know if it etches any slower because I did not time it when new. When it is nearly gone I may get a new supply and run a test with two identical boards to see if the old is slower. Still good stuff but stocking up might be a bad idea. Quote:
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) | ||
| CAN somebody please tell me; what amount of Ferric Chloride (anhydrous) to be mixed with what amount of water for etching one 9cm x 5cm board. Please!!!!! | |
Determine how much solution it will take to cover the board or fill you etching tank. Your choice. Earlier Torben linked to a page that pointed out 100 grams of crystals per 200ml of water. Just do it.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 30th August 2008 at 02:39 PM. | ||
| Hi, check out here a nice tutorial on making pcb using the etchant ferric chloride, a laser printer and an iron!! really effective one, check it out: http://electrons.psychogenic.com/mod.../pcb_howto.php it's simple n useful for do-it-yourself kind of projects. Recently i tested it by making a single layer ATmega32 experiment card. it took 2 hours for etching (i didn't steer the liquid frequently). U can check my board design here: http://dharmanitech.blogspot.com/200...rters-kit.html Enjoy! ------------------------- http://dharmanitech.blogspot.com | |
What helps most this kind of mixes is a little of heat and shaking a little. Warning: That stuff is toxic !!! And it damages most clothes, others can be clean with anti ferric chloride. | ||
| Can somebody please answer to this: For toner transfer method; can I take print from the shops called "digital printing shops" I mean can I make a toner transfer from professional digital print on some glossy paper?? | |
EDIT: You may want to have them print the image on each type of glossy paper they stock. That is if they stock more then one.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 3rd September 2008 at 03:00 PM. | ||
| I Knew that.I wanted to know can I use the copies, which were not printed from laser printer but was printed from online or offline professional digital photo printing stores.like http://www.printcamp.com/aboutbuyprints.php or http://www.picsquare.com/ or http://www.itasveer.com/ Last edited by theo92; 3rd September 2008 at 05:44 PM. | |
| It is as simple as this. If the pictures are not printed with a laser printer or copier there will be no toner to transfer. I would think these places use photographic paper for printing photos.
| If always used FE3CL, if I remember that right. I always also used positive 20 to get the tracks onto the board. Spray positive20 on whole board, allow ample time to dry in a dark place, I used to print two copies of the tracks on transparencies using ink-jet, then stick that to the board with the help of few drops water and some cellotape. I would just use the sun for my UV exposure for the po20, luckily in RSA here, then caustic soda to eat the exposed po20, and then your FE3CL bath. I used to heat mine using a fish tank heater, and put some bubbles through it using a fish tank air pump as well with a specially modified pipe to make many small bubbles to run across the face of the board. Yes, I know, tedious process, but I believed it to be cost effective enough to do so. Never knew at the time how toxic the stuff was, just that it stained everything, and ate everything metal. | |
| FE3CL.....is it ferric chloride aka FeCl3 ? I used FeCl3 anhydrous, when mixing the solution, I very small drop spalshed in to my one eye as I just forget to wear eyewears. There was not too much pain as the concentration of fecl3 in the water was too low. my mother washed my eyes with a lots of complain about my neglehency. Now, I'm fine. No fear, FeCl3 will do nothing if you know what is it. It is not too dangerous as I thought. Though TAKE PRECAUTIONS. | |
| Don't know how much use this would be to you guys but I have emailed my electronics teacher regarding the method and equipment he uses. It will be pretty safe as it is used in schools by 13 year olds. I will post his response if it is of any use when I get it. | |
| PNP switching method | wingerr | General Electronics Chat | 10 | 5th April 2008 02:46 PM |
| Pic A2D Input Method. | richard.c | Micro Controllers | 2 | 28th December 2007 08:46 PM |
| getting 5v for IC, best method | gints | General Electronics Chat | 4 | 23rd August 2006 01:24 AM |
| The BEST method? | mstechca | General Electronics Chat | 2 | 24th September 2005 02:54 PM |
| third method of SSB generation (weaver's method) | samcheetah | General Electronics Chat | 2 | 3rd March 2005 11:51 AM |
