Old 23rd June 2008, 05:26 PM   (permalink)
Default SLA: circuit to check if the battery needs to be replaced
Hi!
I have a pcb that is being powered by mains and backed-up by a 12V SLA rechargeable battery.
Due to charge and discharge cycles, the SLA battery might lose its properties.
So I would like to if there are any methods to check if the battery needs to be replaced or not.
I have an ADC so I can read SLA battery voltage and do some calculations.
I guess there is a method of applying a constant load, pulling a certain amount of current from the battery and by reading its voltage it might be possible to determine whether the battery is ok or needs to be replaced.
Is anyone aware of such methods?
Any papers about this and the theory behind it?
logicnibble is offline
Old 23rd June 2008, 07:27 PM   (permalink)
Charge the battery to full and then measure the voltage under no load. SLA 12VDC batteries are actually 13.8VDC but if its fully charged and reads around 13.4VDC (like mine) they are probably old.
Krumlink is offline
Old 23rd June 2008, 07:53 PM   (permalink)
Originally Posted by logicnibble View Post
Hi!
I believe the simple algorithm that you describe is at the heart of automotive battery "exerciser"-type chargers. I'm no expert, but an increase in the internal resistance of an SLA battery would be a pretty good indicator of wear. The question then is, how much is too much?
I got some pretty good education at this site:
VARTA Automotive*-*Battery know-how
google for "load testing lead acid batteries" and you will get a lot of hits
RadioRon
RadioRon is offline
Old 24th June 2008, 01:02 AM   (permalink)
The following method would give a good indication of the heath of the battery:
1. Fully charge the battery
2. Apply a constant current discharge load of "C" to the battery. e.g. a 12V 20AH batery would be a 20A and a 12V 6AH battery would be 6A discharging current.
3. Record the battery terminal voltage 10 seconds after start of discharging, and then again after a minute. Try this method first with a few new and fully charged batteries so you can get yourself some reference figures of what to expect.
4. Most bad batteries will fail to last the duration of the test or show up with a very large drop in terminal voltage.
L.Chung
eblc1388 is offline
Old 25th June 2008, 11:36 AM   (permalink)
Hi!
Thank you all!
I've done some more research (thanks RadioRon, I guess I wasn't using the right search strings) and here is a summary of what I've got:
Heavy-load test:
Battery must be at least 75% charged
During the test the voltage should not fall below 9.6V. Otherwise, replace the battery.
The test should last 15 seconds the maximum
The correct load should be 1/2CCA or 3xAh
LM3909 replaced??? mindctrl General Electronics Chat 5 12th May 2008 11:04 PM
Can Anybody There...check This Circuit... drinalds General Electronics Chat 2 4th February 2008 05:51 PM
please check this circuit max_imum2000 Robotics Chat 8 2nd December 2006 05:40 PM
Circuit check please? kybert Electronic Projects Design/Ideas/Reviews 9 29th December 2004 01:36 PM
Please, check my circuit =) Thorpydo Micro Controllers 6 6th August 2004 03:53 AM
