Old 21st June 2008, 01:37 PM   (permalink)
Default Making pulsed DC measurement
Hello, I am having trouble making a pulsed DC measurement using a 34401A DMM. The unit that we are trying to measure generates a 350uS pulse of approximately 950mV at a rate determined by the trigger input, which we are using a simple pulse generator for. We can measure the pulse amplitude on the scope, but we need something more accurate. We set the meter to trigger externally and connected the signal that we are using to trigger the unit under test. The problem is that the meter triggers on the negative edge of the trigger pulse and the UUT requires that the trigger pulse be longer than 350uS, so it is not measuring the pulse amplitude. We can't find anywhere in the manual where it gives a setup for this situation, other than a short section on external triggering. We also have a 3458A available. Thank you for any help.
superbrew is offline
Old 21st June 2008, 08:00 PM   (permalink)
Just set the oscope input to DC and use it as a comparetor, use a variable power supply set to the amplitude of the pulse you are measuering. You should be able to get close to the accuracy of your DVM.
Rolf is offline
Old 22nd June 2008, 10:29 AM   (permalink)
Thanks for the suggestion Rolf. We would like to be able to do this with a minimum amount of equipment, though. Also, some of our test points are < 100mV, so setting the power supply at those points can be tricky.
Old 22nd June 2008, 05:06 PM   (permalink)
The 34401 is probably not fast enough for you measurement but the 3458A voltmeter has a maximum read rate of 100k samples/sec so it should be able to take your reading with that in the external trigger mode. It does trigger on the negative edge of the trigger pulse so you will need to invert the pulse. If you have a pulse generator available you can use that to invert (and delay the pulse if necessary) to the point on the waveform you want to measure.
Carl
crutschow is offline
Old 22nd June 2008, 08:52 PM   (permalink)
I should have said a stable adjustable voltage source. You might even be able to use what you have with the addition of two ten turn pots, one for course and one for fine adjustment.
When you don't state how much accuracy you need it is difficult to help.
Rolf is offline
Old 22nd June 2008, 09:01 PM   (permalink)
the scope should be fine for a repetitive pulse. you need a good digital scope for a single impulse.
Ubergeek63 is offline
Old 22nd June 2008, 11:36 PM   (permalink)
The spec for the unit is 1% of indicated value, so we need at least .25%. My main question was for technique required to measure this pulse with a DMM. I will see what I can do with the 3458A. I wil porbably just make a test jig to invert the trigger pulse from the generator. Thanks for the help all.
Old 22nd June 2008, 11:41 PM   (permalink)
perhaps I am reading to much into it...a peak detector?
high voltage pulsed dc jazzyb Electronic Projects Design/Ideas/Reviews 8 9th February 2008 08:49 PM
SPL PL90-3 75W 905nm pulsed laser diode TheVictim Datasheet/Parts Requests 1 15th November 2007 12:56 AM
Pulsed collector current 4n33 optoisolator? William At MyBlueRoom General Electronics Chat 4 22nd June 2006 10:51 PM
LED Flash light ..Pulsed LED, underdamped oscillations williB General Electronics Chat 120 17th June 2005 09:07 PM
Pulsed Solenoid?? captainkirksdog General Electronics Chat 4 7th September 2004 01:16 AM
