Originally Posted by
rjvh
Hi I am wondering for what the relation is of the power decrease if you cap a sinus through a transformer.
a transformer can only transform energy if the field is moving.
so if you cap the sinus for example with one third from the peak than the output peak will also be 1/3 smaller but the time that the field is moving halved so the energy transformation is than also halfed??
if i have a transformer that is 220V/36V 250VA and i cap the sinus with roughly 1/3 to 150V.
the output voltage will than be about 24 a 25 V but is the power rating than 166.6 VA, or is the power rating 125VA because the time that the field is changing is only half than original?
second question is how do i achief this caping of the sinus with the netpower
what i did draw, I know that that is probably not the way I should do it.
what i have in mind is that if i have 1 type of transformer
for 2 situations.
First situation is having 3 lamps of 12V in serie and with reducing the voltage i would have a dimm option as over the 3 lights only 24V fals.
second situation is if i want to conect only 2 lamps of 12V in series, 2/3 of the 36 volt will make 24 volt
first i thought to solve this with a dimmer but that will result in the second situation that the peak will always be 36V and it would blow the lights
can sombody give me some insight on this?
Robert-Jan
