Old 8th July 2008, 06:30 AM   #31
OOMPH is power.
The output transistors in the class-AB circuit don't have enough base current to drive an 8 ohm speaker properly.
Electromaster fixed the software bug that caused the temporary attachment quota problem.
Class C is used in radio circuits where an LC tuned circuit removes the harmonics that are caused. Class-C would cause severe distortion (lots of harmonics) in an audio amplifier.
Class-D amplifiers have a very complicated high frequency pulse-width-modulation switching circuit.
There are sites that host your schematics and pictures. Some of them have horrible pop-up ads. Some of them take forever to wake up.
Here is a simulation of Hero's modifications:
audioguru is offline
Old 8th July 2008, 01:01 PM   #32
Here's a slightly improved version, it's not perfect or efficient but it has lower bias resistors for more power and negative feedback (provided by R1 to R3) to remove the distortion.
if I know the answer.
Hero999 is offline
Old 8th July 2008, 04:12 PM   #33
Hi Hero,
Your modified amp is much better.
Except its voltage gain is very low (2.6) and its input impedance is very low (about 2k).
Old 8th July 2008, 04:23 PM   #34
Originally Posted by audioguru View Post
Hi Hero,
hi agu,
If you have not already got this link, I think you may find it useful.
INTRODUCTION TO DIGITAL FILTERS WITH AUDIO APPLICATIONS
ericgibbs is offline
Old 8th July 2008, 05:01 PM   #35
Originally Posted by ericgibbs View Post
hi agu,
Hi Eric,
Thanks but no thanks.
The article is for mathamaticians who are designing ICs. I haven't used math for many years and I have never designed an IC.
I designed audio filters with opamps. I worked with products with DSP ICs that had programmed filters.
Old 8th July 2008, 07:30 PM   #36
Hi Hero,
That's what negative feedback does for you but at least it will drive the speaker, there's no distortion and you need to add a pre-amplifier to make this circuit useful.
You could make Q1 a darlington and R1 1M if you want more gain.
Hero999 is offline
Old 10th July 2008, 06:26 AM   #37
i have just downloaded the file couldnt get online all this time.listen here is a different transistor switch i found something like this in the forum.for the one on the left it was said that the led wud light if the base was driven low and for the right it was said that it would light when the base was driven high.i have measured the voltage and the currents as seen in the picture also can you tell me how its working.i understand the first one because npn sinks current correct me if i am wrong? and what is thje reason for the humangous current in the right hand side circuit??
Wond3rboy is offline
Old 10th July 2008, 03:57 PM   #38
No. The LED and the transistor would burn out as shown without a current-limiting resistor. The 10k resistor applies base current to the transistor to turn it on. Then the base is about +0.7V. If you connect the base to 0V then the transistor will turn off.
You had the LED connected directly across the battery so it would burn out instantly. You had the transistor connected so that it shorts the battery and burns out.
My corrected circuit shows a current-limiting resistor in series with the LEDs.
The circuit on the right has the transistor connected as an emitter-follower so that its emitter is about +11V as shown and if the base is connected to 0V then the transistor turns off.
Did you notice that on my schematic there are no wires running all over the place and no wires cross?
Old 10th July 2008, 06:12 PM   #39
I comfused, I thought this thread was supposed to be about an audio amplifier not switching LEDs?
Hero999 is offline
Old 10th July 2008, 08:13 PM   #40
Yeah, Wond3rboy hijacked Patroclus' thread, but he appears to have abandoned it.
Ron
Roff is online now
Old 14th July 2008, 05:27 AM   #41
Hero999 sorry for that but since you didnt carry on with the thread so i thought why not continue to learn from it rather than starting a new thread
Old 15th July 2008, 07:54 AM   #42
Question
hey audioguru,can you tell me how did you calculate the i/p impedence of heros amp.i mean you cal the i/p impedence of the ce amp and then how did you calculate the ab amps i/p impedence and what about the o/p impedence of the ce amp cuase it is also seen by the power amp.
Old 15th July 2008, 04:18 PM   #43
I just guessed. In the simulation the input impedance is 1360 ohms.
The input impedance of a common-emitter transistor is hFE times its internal re plus hFE times its RE, then any biasing resistors in parallel.
The internal re of a silicon transistor is 0.026/emitter current in milliamps.
The output impedance of a common emitter transistor is its collector resistor. The transistor itself is a current-sink with a very high impedance. Negative feedback from the output to the input reduces the input impedance and reduces the output impedance.
The output impedance of Hero's amplifier is so low that it cannot be measured on the simulation. Most good power amplifiers have an output impedance of 0.04 ohms or less at low frequencies.
Old 17th July 2008, 05:40 AM   #44
thank you very much!
can you tell me some other things i am supposed to work at inorder to improve my electronic skills?
Old 18th July 2008, 07:26 AM   #45
One more question:What is hte effect of bootstrapping an amplifier except reducing the impedence of an amplifier?
amplifier, bjt, stage
2 Stage JFET amplifier AlphaRay86 General Electronics Chat 3 10th December 2007 05:54 AM
3 Stage amplifier Design Help!!! tonyk Electronic Projects Design/Ideas/Reviews 15 1st June 2007 02:30 PM
Multi-stage MOSFET Amplifier design.. cqbrules Electronic Projects Design/Ideas/Reviews 3 1st March 2005 09:44 PM
Single Stage Common Emitter Amplifier ad353 General Electronics Chat 2 7th June 2004 05:52 PM
2 stage differential amplifier mozikluv General Electronics Chat 1 12th September 2003 03:43 PM
