| | #16 | ||
If you did have infinite beta in Q2, you would be driving about 800mA DC through the speaker. This is not a good idea, to understate the case. Last edited by Roff; 1st July 2008 at 02:09 PM. | |||
| | #17 |
i have uploaded the ckt itself.by the way also specify what effect increasing the frequency or decreasing it above the high pass filter.
| | #18 |
| I downloaded your file and simulated it. Below are the waveforms on the Q1 collector and the Q2 base. Notice the distortion, and the DC level at the base of Q2. Why do you think this is happening?
| | #19 |
i deletd teh capacitor and it seems to be working fine,but i chose the capacitor values accodrding to the 20hz filter!!
| | #20 | |
If simulators were guns, you'd be dead by now! | ||
| | #21 |
sorry!!the capacitro c2.i deleted it and the o/p was k.what i dont understand is why the filter made by c2 and the r5parallelr6 distorting the o/p?have i miscalculated the value of the capacitor??sorry agaian!!!
| | #22 | |
As I said before, it is not a good idea to drive a speaker with DC. | ||
| | #23 |
thanks very much!!until the next problem! | |
| | #24 |
I've modified your circuit so it drives an 8 hm: speaker with no problem.The forum wouldn't let me attach the .asc file so I've enclosed it in code tags. Just paste it into a text editor such as notepad of emacs, save it as a .asc file and open it in LTSpice. Code: Version 4 SHEET 1 880 680 WIRE 304 -240 -336 -240 WIRE -448 -192 -592 -192 WIRE -336 -192 -336 -240 WIRE -336 -192 -448 -192 WIRE -144 -192 -336 -192 WIRE -16 -192 -144 -192 WIRE -448 -176 -448 -192 WIRE -592 -144 -592 -192 WIRE -16 -144 -16 -192 WIRE 304 -112 304 -240 WIRE -144 -96 -144 -112 WIRE -80 -96 -144 -96 WIRE -144 -32 -144 -96 WIRE -16 -32 -16 -48 WIRE -448 48 -448 -96 WIRE -368 48 -448 48 WIRE -144 48 -144 32 WIRE -144 48 -304 48 WIRE -16 64 -16 48 WIRE 48 64 -16 64 WIRE 144 64 112 64 WIRE -144 80 -144 48 WIRE -16 80 -16 64 WIRE -448 96 -448 48 WIRE -784 144 -944 144 WIRE -592 144 -592 -64 WIRE -592 144 -720 144 WIRE -512 144 -592 144 WIRE -592 192 -592 144 WIRE -144 208 -144 144 WIRE -80 208 -144 208 WIRE 144 208 144 64 WIRE -944 224 -944 144 WIRE -448 224 -448 192 WIRE -144 224 -144 208 WIRE -944 336 -944 304 WIRE -592 336 -592 272 WIRE -592 336 -944 336 WIRE -512 336 -592 336 WIRE -448 336 -448 304 WIRE -448 336 -512 336 WIRE -352 336 -448 336 WIRE -144 336 -144 304 WIRE -144 336 -352 336 WIRE -16 336 -16 256 WIRE -16 336 -144 336 WIRE 144 336 144 288 WIRE 144 336 -16 336 WIRE -512 352 -512 336 WIRE -352 400 -352 336 WIRE 304 400 304 -32 WIRE 304 400 -352 400 FLAG -512 352 0 SYMBOL npn3 -512 96 R0 SYMATTR InstName Q1 SYMBOL res -608 -160 R0 SYMATTR InstName R1 SYMATTR Value 10k SYMBOL res -608 176 R0 SYMATTR InstName R2 SYMATTR Value 1k SYMBOL res -464 208 R0 SYMATTR InstName R3 SYMATTR Value 100 SYMBOL Misc\\signal -944 208 R0 WINDOW 123 0 0 Left 0 WINDOW 39 0 0 Left 0 SYMATTR InstName V2 SYMATTR Value SINE(0 .5 400) SYMBOL res -464 -192 R0 SYMATTR InstName R4 SYMATTR Value 1k SYMBOL res -160 -208 R0 SYMATTR InstName R5 SYMATTR Value 1k SYMBOL res -160 208 R0 SYMATTR InstName R6 SYMATTR Value 1k SYMBOL npn -80 -144 R0 SYMATTR InstName Q2 SYMBOL Misc\\battery 304 -128 R0 WINDOW 123 0 0 Left 0 WINDOW 39 0 0 Left 0 SYMATTR InstName V1 SYMATTR Value 20 SYMBOL res 128 192 R0 SYMATTR InstName Speaker SYMATTR Value 8 SYMBOL cap -304 32 R90 WINDOW 0 0 32 VBottom 0 WINDOW 3 32 32 VTop 0 SYMATTR InstName C2 SYMATTR Value 10µ SYMBOL pnp -80 256 M180 SYMATTR InstName Q3 SYMBOL diode -160 -32 R0 WINDOW 0 39 32 Left 0 WINDOW 3 -28 29 Left 0 SYMATTR InstName D1 SYMBOL diode -160 80 R0 WINDOW 0 42 30 Left 0 WINDOW 3 -29 30 Left 0 SYMATTR InstName D2 SYMBOL res -32 -48 R0 SYMATTR InstName R7 SYMATTR Value 1 SYMBOL res -32 64 R0 SYMATTR InstName R8 SYMATTR Value 1 SYMBOL Misc\\EuropeanPolcap 48 80 R270 WINDOW 0 32 32 VTop 0 WINDOW 3 0 32 VBottom 0 SYMATTR InstName C3 SYMATTR Value 1000µ SYMBOL cap -720 128 R90 WINDOW 0 0 32 VBottom 0 WINDOW 3 32 32 VTop 0 SYMATTR InstName C1 SYMATTR Value 10µ TEXT -752 -32 Left 0 !.tran 0 5 1 1
| | #25 | |
Disclaimer: I am not an audio guru. ![]() You can drive a speaker with that, but the gain is low and I think the distortion will be high if you want enough power to actually hear it. | ||
| | #26 |
I tried adding negative feedback around the entire circuit and many other things but the output transistors do not have enough OOMPH. I cannot make an attachement because it say that I have exceeded my attachments quota!!!!! Again. Last time i deleted all my attachments then admin removed the quota. Now the quota is back!
__________________ Uncle $crooge Last edited by audioguru; 7th July 2008 at 05:13 PM. | |
| | #27 |
well thanks roff making a power amplifier for running my 8ohm speaker was my seond task.i am practising making amplifier and different types of circuits.any hints??
| | #28 |
The circuit I posted isn't perfect, I just made the bare minimum number of changes to enable it to drive an 8 hm: speaker.I certainly don't plan to remove any of my attachments. Attachmets are a good thing but they aren't really needed, an external hosting service is all that's required.
| | #29 | |
| | #30 |
[QUOTE=audioguru;325591]I tried adding negative feedback around the entire circuit and many other things but the output transistors do not have enough OOMPH. OOMPH?? and if you dont mind me asking why we dont use a class c or d amplifier because i have seen most of the people make clas ab amps as power amplifiers.AND from where can i learn about class c and d amps? Which external service are you talking about? | |
| amplifier, bjt, stage |
| 2 Stage JFET amplifier | AlphaRay86 | General Electronics Chat | 3 | 10th December 2007 05:54 AM |
| 3 Stage amplifier Design Help!!! | tonyk | Electronic Projects Design/Ideas/Reviews | 15 | 1st June 2007 02:30 PM |
| Multi-stage MOSFET Amplifier design.. | cqbrules | Electronic Projects Design/Ideas/Reviews | 3 | 1st March 2005 09:44 PM |
| Single Stage Common Emitter Amplifier | ad353 | General Electronics Chat | 2 | 7th June 2004 05:52 PM |
| 2 stage differential amplifier | mozikluv | General Electronics Chat | 1 | 12th September 2003 03:43 PM |
