Old 19th June 2008, 04:24 PM   (permalink)
Default Solenoids and clamping diodes
I'm using a microcontroller to control the length of time a solenoid is kept energized, in combination with an n-channel mosfet. I understand the importance of a clamping diode to handle the inductive voltage created when the magnetic field collapses.
However, I've also noticed that the presence of the clamping diode reduces the speed at which the solenoid opens and closes, and this has an effect on my timing and cyclic rate. Is there a certain kind of diode that is better suited for this scenario? So far I've been using schottky fast recovery diodes. If there's some way I can protect the mosfet without slowing down the solenoid, that would be even better.
Thanks in advance.
FlipFlops is offline   Reply With Quote
Old 19th June 2008, 04:35 PM   (permalink)
The diode might delay the opening time but should not effect the closing time. You could try a zener in series with the diode.
That way the inductance can discharge into a higher voltage so the field can collapse quicker. For instance if you have a 12V rail and a 50V FET put in say a 25V zener.
Ubergeek63 is offline   Reply With Quote
Old 19th June 2008, 06:55 PM   (permalink)
Uber,
Thanks for the info. Would a zener diode by itself suffice?
Old 19th June 2008, 10:20 PM   (permalink)
You can use a resistor and capacitor instead of a diode. You can then adjust the R and C to change the opening and closing time.
If you used a TVS diode of the right clamping voltage then it should improve things. It's like a zener diode, but much faster. A zener diode is designed to clamp steady voltage, and a TVS diode is designed to clamp fast transients.
You might also try using a bunch of your fast recovery diodes in series so the clamp voltage is higher but still within safe limits. That should also reduce the opening time.
NO, that picture isn't me so don't bother asking if we can be friends.
Old 19th June 2008, 10:54 PM   (permalink)
No. The zener polarity has to be opposite polarity to the normal diode. Otherwise the zener would just act as a normal diode.
Carl
crutschow is offline   Reply With Quote
Will a rectifier diodes work as protection diodes in a relay app? Andy1845c General Electronics Chat 12 15th November 2007 09:42 PM
Do I need clamping diodes on PIC A/D ports? William At MyBlueRoom Micro Controllers 4 15th August 2006 08:07 AM
Solenoids mdj21 General Electronics Chat 19 10th December 2005 07:12 PM
Why would you use a clamping diode when using a relay? Moffatt General Electronics Chat 14 24th April 2004 11:11 PM
Solenoids shermaine General Electronics Chat 1 22nd August 2003 04:38 AM
