Old 18th June 2008, 12:48 AM   (permalink)
Default DMX vs Audio Cable Question
Are there any adverse problems arrising from using DMX cable for audio cable? This is the 3 pin XLR connector. Want to use the cable from microphone to mixer. I believe the DMX cable is 120 ohms impedence and the audio cable is supposed to be 72 ohms impedence. Will the audio be degraded signifigantly? Have not tried it yet, wanted some advise first.
Thanks,
Neal
Neal is offline
Old 18th June 2008, 01:10 AM   (permalink)
Depends on distance, and actual impedance of the microphone and mixer. At short distances it won't matter. What is your quality expectation?
mneary is offline
Old 18th June 2008, 01:26 AM   (permalink)
Forgot to mention the distance is 100 ft. It's just picking up audio above stage area for a play, as long as we get something decent, it should be ok.
Is 100 ft. too long?
Neal is offline
Old 18th June 2008, 01:45 AM   (permalink)
The DMX standard is intended to be like a RS-485 multi-drop bus to control theater equipment. I believe these cables are UTP ( Unshielded Twisted pair ) and as such, I do not think they would do well in a noisy audio environment. Lots of hum I would guess.
http://www.belden.com/pdfs/Techpprs/DMX-512.pdf
Mikebits is online now
Old 18th June 2008, 02:02 AM   (permalink)
Also let me add, at a 100ft, I think it will sound like crap, but I have been wrong before.
Old 18th June 2008, 02:21 AM   (permalink)
I just took an end off the connector to see, it looks like 2 conductors, both are shielded individually and shields tied together.
Neal is offline
Old 18th June 2008, 02:29 AM   (permalink)
I hate when I am wrong. I guess you should just try it and see. Or is that listen.
Old 18th June 2008, 02:40 AM   (permalink)
Will be not able to test til tomorrow at facility, however am hopeful it should be ok. I now think the new DMX cables will be ok for audio. However, I believe the old standard single shielded audio cable may be too noisey for DMX controller aplications. Will post results after I can test it out tomorrow night.
Neal is offline
Old 18th June 2008, 02:45 AM   (permalink)
If it's shielded you're probably fine. If you get a lot of 60hz hum try cutting the shield grounds at the mic and keeping them separate. The shields only need to be saftey grounded at the mixer/amp they'll ground out anything the 100ft of wire picks up.
straight answer, har har."
Sceadwian is offline
Old 18th June 2008, 08:39 AM   (permalink)
Audio cable doesn't have a specific impedance, it's not used as an impedance matched system.
As long as the cable is well screened, the inner cores are twisted, and it's anti-microphonic, then it will be fine.
If, as you say, the cores are individually screened, then it won't be as good at rejecting external noise and interference.
Old 19th June 2008, 11:14 PM   (permalink)
Thanks,
Neal
Update DMX cable worked fine for audio, no hum, good quality
Neal is offline
Old 19th June 2008, 11:37 PM   (permalink)
Oh no, I see a red square coming for me. Don't I feel silly
Glad it worked out for you ...
Old 20th June 2008, 08:57 AM   (permalink)
You've obviously not done PA or recording, the low impedance and balancing of the mikes allows long cables with minimum loss. Using high impedance mikes means you can only have short leads, otherwise you get HF loss, due to the impedance of the mike and the capacitance of the cable forming a low-pass filter.
75ohm audio cable for svideo? bh00 General Electronics Chat 3 30th December 2006 09:23 AM
Ideas on circuit to separate audio signal from cable tv?? fshrmn Electronic Projects Design/Ideas/Reviews 10 27th September 2005 06:54 PM
What cable for Front Pannel Audio connector? grrr_arrghh General Electronics Chat 1 13th March 2004 03:40 PM
Converting from Audio/Video cables to a Coaxial cable Talligan General Electronics Chat 5 5th September 2003 01:25 AM
Very long cable audio link Spex General Electronics Chat 0 30th June 2003 10:27 PM
