Old 17th June 2008, 09:54 PM   (permalink)
Question SMD tactile switches.
Hi all,
I've recently had some problems with my car alarm remote. Having opened it to take a look I noticed that the tactile switched are not working all of the time. I think if I change them it will solve my problems.
The only problem with changing them is this, the switches in the remote are small, 'low profile' ones and I can't seen to find them anywhere.
The switch measures 6mm square, and are only about 1.5mm - 2mm thick. There is not enough room in the remote case to use the 'standard' ones I have which are about 5mm thick.
Does anyone know a source for these switches? I'd be looking at replacing all of the switches in both remotes so I would need 6 in total so I'd rather not have to buy silly amounts (ie not more than say 15-20 of them). Also I would prefer a UK supplier so I don't have to pay silly postage costs for a few switches.
Thanks in advance for any help.
'Intellectuals solve problems. . . Geniuses prevent them.' . . . Albert Einstein
fingaz is offline
Old 17th June 2008, 10:14 PM   (permalink)
Are these the kind which have a small black lump of stuff which gets pressed against some traces on a PCB below them? If so, I'd first try taking a Q-tip and some rubbing alcohol and giving the PCB and lump (what is that lump, anyway? Ferrite?) a quick scrub.
Used to work wonders for our keyboardist's synthesizers. I've also cleaned up phone keypads, remote controls, etc like this.
Torben
Torben is offline
Old 17th June 2008, 10:21 PM   (permalink)
Is it just a piece of metal attached to the PCB?
I don't think there's anything you can do apart from clean it as it's likely to be custom built for the control.
Screen name: Aloone_Jonez
Hero999 is offline
Old 17th June 2008, 10:39 PM   (permalink)
Something like these maybe?
http://www.e-switch.com/pdf/TL3342.pdf
Mikebits is offline
Old 17th June 2008, 10:46 PM   (permalink)
Maybe Sparkfun SKU#: COM-08720?
(Sorry it's not UK).
mneary is offline
Old 17th June 2008, 10:48 PM   (permalink)
Have you tried major suppliers like Digikey, Mouser, or Newark. I found these at Mouser. You are in the UK so I would try Farnnel/Farnel(?sp) which is the parent company of Newark.
2.5 mm high switch or this .25 mm hight switch
3v0 is offline
Old 17th June 2008, 11:32 PM   (permalink)
Posting a picture would also probably make it much easier for us to help.
Hero999 is offline
Old 18th June 2008, 11:12 AM   (permalink)
Hi fingaz,
I get these things in the shop regularly for repair, Farnell sell replacement switches for most remotes although they now have a minimum of £20 for credit card orders.
By far the most common cause of failure on these remotes is bad solder around the switch connections, it would be best to check this before you start ordering switches (you will need a very strong magnifier).
SYE is offline
Old 18th June 2008, 01:35 PM   (permalink)
Panasonic makes all kinds, Digi-Key sells them.
Dean
R.I.P.
Dean Huster is offline
Old 19th June 2008, 08:53 AM   (permalink)
Thanks Mikebits, these are exactly what I'm looking for. Where am I likely to get these?
SYE : I already tried cleaning and re-soldering the switches and it didn't improve anything.
Thanks to everyone else.
fingaz is offline
Old 19th June 2008, 05:26 PM   (permalink)
Looks like Digi-key stocks E-switch products.
E-Switch - Vendor Home
Mikebits is offline
Switches. Baske7Cas3 General Electronics Chat 17 23rd July 2007 07:13 AM
Tactile Switch Trouble Meatmod General Electronics Chat 8 13th January 2007 05:54 AM
Meaning of tactile switch Spectacular Butter General Electronics Chat 6 25th February 2005 12:02 PM
switches vieri Micro Controllers 6 2nd October 2003 04:35 PM
Where Can I Buy These Switches? less_than_jake_2002 Datasheet/Parts Requests 1 17th July 2003 05:59 AM
