Old 17th June 2008, 11:09 AM   (permalink)
Default Charging a li-ion cell?
Hi guys. I recently bought a new laptop battery, since my old one had 3 mins life after being disconnected from the power. So I decided to rip the old one apart. They seem to still have a 4V charge under no load. They look like a oversized AA, and seem to have built in protection circuitry. Anyone know how I could build a charger that would safely charge these things? I know they are slightly dead, but they re still holding a charge pretty well. Here is a pic of it next to a normal AA
The 3 laws of science....
1. If it smells bad, It's chemistry.
2. If it's mushy, It's biology.
3. If it doesn't work, It's physics.
www.laserpointerforums.com A forum for disscusion of lasers and laser shows!
www.laserchat.org IRC chat for laser and electronic related stuff.
things is offline
Old 17th June 2008, 11:36 AM   (permalink)
safely charging those things is beyond normal experimenter techniques, you need a special charger.
if you want something you can safely charge try the LiFePO4 chemistry:
DealExtreme: $4.19 18650 Rechargeable Lithium LiFePO4 Battery (1350mAh)
Ubergeek63 is offline
Old 17th June 2008, 06:51 PM   (permalink)
Wink
Hi.
Apply not more than 4.2000 Volts to the cell at any current rate that does not warm them up. ---> 4.1V is fine !
(Use a fixated voltage regulator) That's it.
Do not charge several in series. You do can charge several in parallel.
There is fancier ramping methods to charge them to extreme 99.9% capacity but do not get into that specialized circuitry for general purpose use. You do not need any 'special' chargers
Miguel
Abolish the deciBel !
Externet is offline
Old 17th June 2008, 10:43 PM   (permalink)
You shouldn't charge Li-ion:-
When below -10 deg C
When above +40 deg C
Faster than 1 hour
Faster than at the 100 hour rate if the voltage is less than 3.2V
as well as the suggestions from Externet
Diver300 is online now
Old 17th June 2008, 11:11 PM   (permalink)
Charging,
I'm at the moment charging a Li - ion battery from a camera from which the charger got lost.
I usually stick with a charging current of between 5 and 10 % from the Ah Capacity.
At 5% you can leave it safely on charge for 24 hours.
At 10% rate I would check after 1 hour or so that the cell is not excessively warm otherwise reduce the charging current.
For current below 50 mA , I often put a LED in series which gives a visual indication of charging.
I use a normal DC power supply and use a series resistor in line 56 or 100 hm: 1/2 watt is fine.
RODALCO is offline
Solar Cell Capacitor Charging Circuit - Analysis Question crice General Electronics Chat 4 28th February 2007 10:06 PM
Cell Phone Charging - Interesting Find klm General Electronics Chat 4 23rd December 2006 08:16 AM
The Joe Cell mramos1 Alternative Energy 60 8th November 2006 10:28 PM
In car SLA charging joecool85 General Electronics Chat 14 19th September 2006 12:53 AM
Cross-Coupled Nor Gate Cell and Cross-Coupled Nand Gate Cell shermaine General Electronics Chat 5 24th March 2004 11:49 PM
