Old 18th June 2008, 07:03 AM   (permalink)
as explaned in the other post from yesterday by eric gibs: if you put aditional AND gates and play with the outputs of the 4060 you will get that
if it comes to the blinking part than a micro processor based circuit will be the most simple and economical solution to do it
it still can be done on the conventional way but you get a much more complex circuitry
Robert-Jan
rjvh is offline
Old 18th June 2008, 07:46 AM   (permalink)
I'm sorry Robert-Jan, but I don't understand your answer.
I don't know which outputs can function the way I've just explained.
The blinking is another painful problem...
barakorit is offline
Old 18th June 2008, 07:55 AM   (permalink)
if you have a look on the data sheet of the 4060 than you see it has 10 outputs if you combine some of the outputs by the use of a AND gate than if both inputs are high the output of the AND gate will also be high
so if you have a on pulse from 16 min on 1 output than you need to find another output that is on for 8 min (pin nr 2 if you use pin nr 3 for the 16 min out)
if you put both out puts in an AND gate than the led will light up only for the time of 8 min of the 16 min
i will draw something for you but it will take some time as i am working at the moment
Robert-Jan
rjvh is offline
Old 18th June 2008, 08:32 AM   (permalink)
hi Barakorit,
Why have you started another post on the same topic.?
Also 'audioguru' has answered this question on another forum,
see his post of yesterday.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Old 18th June 2008, 08:39 AM   (permalink)
Another question:
How did you calculate the value of the capacitors and the resistors in order to achieve 15min on/off square wave.
Is there any formula or equation for that?
Old 18th June 2008, 08:48 AM   (permalink)
Originally Posted by barakorit View Post
Another question:
Get the datasheet, the formula for the time constants are on the sheet.
Eric
PIC tutorials:
Old 18th June 2008, 08:59 AM   (permalink)
I get a bit anoyed here as i just wrote the whole post and could not submit while the whole tread is now incorporated in this one
please do stick with the tread if it is related and don't make otherones in other sections as it realy gets messy
I put something on paper and to give you a tip
if you put a time frame of 16 min on pin nr 15
than the frequenty doubles at every pin in this folowing order
Pin nr 13,14,6,4,5,7
this in combination with other ports it will give you the base of a blinking signal in the last 2 minutes of the time cycle (16min on pin 15)
get the data sheet for more info
sucsess
Robert-Jan
rjvh is offline
Old 19th June 2008, 10:37 AM   (permalink)
I couldn't understand your question completely.
Is it that you want the green and red LED's to glow simultaneously, for every 4 min.
And each LED should glow for a period of 16 mins?
However whatever you requirement may be it can be acheived by simple programming.
You can take the help from any programming person.
beenuseren is offline
Old 19th June 2008, 10:45 AM   (permalink)
As you have asked previously about obtaining an asymmetrical square wave, you can get it with 4060. You just have to make few more connnections, which would be explained in the datasheet
Old 20th June 2008, 12:48 AM   (permalink)
Hoi barakorit
in my schematic i draw a litle mistake that would result in some outputs going high in the down period
i changed it in the new attachment (see red circled part)
what is actualy the aplication that you want this circuitry to use for??
Robert-Jan
rjvh is offline
Old 20th June 2008, 07:24 AM   (permalink)
Its important to remember when using external gating on the 4060, its a ripple thru counter.
You can/will get switching 'glitches' on the gate outputs, a small R/C filter on the gate outputs, is a good idea.
Eric
PIC tutorials:
Old 22nd June 2008, 04:24 AM   (permalink)
What kind of filter?
What are the values of the R & the C in this filter?
How do youconnect them?
Old 22nd June 2008, 04:30 AM   (permalink)
Hi Robert-Jan
Thanks for the schematic.
In this application, a 2min On/Off square wave doesn't exist (since there is no Q11 in the 4060), but I still need this signal.
Is there any way (a circuit or a component) that generates this kind of signal from another signal in another frequency (the 1min or the 4min On/Off, for example)?
Barakorit.
Old 22nd June 2008, 05:20 AM   (permalink)
if you tune the frequency so that the 16 minute squarewave is located on pin nr 15 than your 2 min square wave will be on pin nr 6
as you did saw on the data sheet there is one output mising in the sequence so try to put your lowest frequency on the output just after the missing one so the other are in folowing order withou interuption
to lower the frequency you can increas the capacitor value and the resistor values
sucses
Robert-Jan
rjvh is offline
Monostable and Astable multivibrator circuit using CMOS gates olgaPB General Electronics Chat 5 24th October 2007 07:29 AM
Astable multivibrator bananasiong General Electronics Chat 10 23rd August 2007 05:38 PM
Astable multivibrator. bitem2k General Electronics Chat 7 1st February 2007 03:29 PM
Astable Multivibrator Design fmang Electronic Projects Design/Ideas/Reviews 1 23rd August 2006 12:21 PM
astable multivibrator to superregen mstechca Electronic Projects Design/Ideas/Reviews 3 24th March 2005 04:29 PM
