Old 13th June 2008, 07:57 PM   (permalink)
Default LED voltage question
I have one of those mini LED flashlights. It has a white LED, which has a turn on voltage of 3 something volts, right? Yet the flashlight runs on a single AAA battery, which only supplies 1.5 volts, right?
How is this possible? What kind of black magic is going on inside my flashlight? And, can I exploit it to power several LED's in my circuits without having to use a 9V or 12V battery?
unseen wombat is offline
Old 13th June 2008, 08:33 PM   (permalink)
Joule Thief - Google Search
Screen name: Aloone_Jonez
Hero999 is offline
Old 13th June 2008, 09:06 PM   (permalink)
Thanks man! You're awesome.
Is there any way to make it smaller? Like is there an IC I could buy? Also, isn't the toroid just acting as an inductor? Could I use an inductor instead?
Old 13th June 2008, 10:08 PM   (permalink)
There are many designs called Joule Thief. Some have been put into very small spaces. Check several of the listed web pages.
mneary is offline
Old 13th June 2008, 11:36 PM   (permalink)
Make a Joule thief.
I wouldn't advise building some of the other projects on his site though.
Make an tingle-tron.
Hero999 is offline
Old 14th June 2008, 12:15 AM   (permalink)
What limits the output voltage range on these? I mean, if you started putting LEDs in series, could this also provide 6V, 9V, 12V and so on?
The most-hated young engineer in America.
* AVR Projects
* Robot War: TI
* About
DigiTan is offline
Old 14th June 2008, 01:21 AM   (permalink)
The Joule Thief has a very small output current so the single LED is lighted but it is not bright.
There are powerful voltage stepup iCs that are made for very bright flashlights.
audioguru is offline
Old 14th June 2008, 05:49 AM   (permalink)
Yeah, I've been using Maxim-IC step-up converters. But I mean, can I also get 18V or more from a joule thief? If these are capable of x12 multiplication or more, I'd like to know how they do it.
* AVR Projects
* Robot War: TI
* About
DigiTan is offline
Old 14th June 2008, 12:12 PM   (permalink)
It depends on the Q of the core, I'd guess you can get 10V to 15V maximum and only at a very low current.
The efficiency will also fall as the output voltage rises.
Hero999 is offline
Old 27th June 2008, 10:39 PM   (permalink)
Okay, something about this is jacked up because I tried this with a 10mm white LED and not absolutely nothing. Even the tiny red ones barely got any illumination and I tired two transformers. Will just any toridal transformer work as long as it has 1:1 coupling?
* AVR Projects
* Robot War: TI
* About
DigiTan is offline
Old 27th June 2008, 11:46 PM   (permalink)
I built a couple of these: 1.5 VOLT WHITE AND UV LED DRIVE CIRCUIT (scroll down to "A Circuit Enhancement") and they worked great. It's just a variation on the Joule Thief idea. I used the 20-tap-20 windings on generic small ferrite toroids using 30 gauge magnet wire as suggested. One fully charged NiMH AA cell ran a 3V white LED for just about 7 days straight before it dropped to about 1/2 brightness.
Torben
Edit: I found a photo of the thing. The tape is just to hold the 30 gauge wire and AA cell in place; the big plastic spike was just over the LED for giggles.
Curiosity was framed. Ignorance killed the cat.
Last edited by Torben; 27th June 2008 at 11:53 PM. Reason: Found a photo of the circuit.
Torben is offline
Old 28th June 2008, 12:23 AM   (permalink)
The Joule Thief operates the LED at a low current so it is not as bright as it can be.
Its brightness might be bright enough for what you want.
Old 30th June 2008, 10:09 PM   (permalink)
By the way, when people are building this: is anyone using breadboards? Normally I won't solder this kind of thing until I've seen it function on a breadboard first. But the the board's stray capacitance is in the way...well...does this also work on breadboards?
* AVR Projects
* Robot War: TI
* About
DigiTan is offline
Old 30th June 2008, 10:14 PM   (permalink)
Mine works just fine on the breadboard. The only component I found that was all that important was the transistor, and it was perfectly happy with 4401, 3904, 2222, and so on, so even that wasn't terribly important.
Again, the one I built wasn't exactly the Joule Thief, but as far as I know it's essentially the same idea.
Torben
Torben is offline
Old 1st July 2008, 09:05 AM   (permalink)
Good call one the modified version. That one is working for me and everything seems to work at max brightness. I used a 2N3904, a 1N4148, and a ceramic 0.1uF capacitor in parallel with different LED variations. My 1watt XLamp was bright enough to provide reading light to a 10x10x10ft room. That's the brightest I've seen it since I bought it over a year ago.
* AVR Projects
* Robot War: TI
* About
DigiTan is offline
Question about low voltage relays wrybread General Electronics Chat 6 27th April 2008 09:13 AM
New question about voltage RC_Racer Electronic Projects Design/Ideas/Reviews 12 14th December 2007 03:13 AM
Reference voltage question. MrMikey83 Micro Controllers 4 24th December 2005 07:48 AM
question on voltage regulators ant9985 General Electronics Chat 3 26th September 2005 03:47 PM
PNP Voltage Switch Question Hopperito General Electronics Chat 24 23rd January 2005 07:31 PM
