Old 19th June 2008, 09:09 PM   (permalink)
3v0
That is not liquid flux it is solder paste used to hold and solder surface mount parts to PCBs.
Everyone has their own idea on how to make PCBs at home. What I use and teach to my students is the toner transfer system from httP://www.pulsarprofx.com. I recomend you use the system with a laminator rather then a clothes iron. The transfer paper they sell will transfer 100% of the toner to the copper. You etch is as good as your laser printer. A photo sensitive method may give better results but this has been good enough.
I use a less nasty etchant called Sodium Persulphate from MG-Chemicals. 4101-1KG It does not rot holes in you lungs or stain the bathroom sink. If you have a real fume hood and a dedicated etching setup Feric Chloride is OK. I will not go back. When the etchan is spend I let it evaporate and store the crystals. When I get a gallon of them (some years) I will take them to a recycling drop.
3v0 is online now   Reply With Quote
Old 20th June 2008, 02:34 AM   (permalink)
Oh wow I feel retarded now. lol Oh well... I guess I have a tube of solder paste...
As far as using Sodium Persulphate instead of Feric Chloride... what are the pros and cons? There must be a downside to using Sodium Persulphate since everyone seems to suggest using Feric Chloride.
I do not own a laminating machine but I do own an iron... for general simple circuits... isn't it okay just to iron the toner onto the copper?
Edit: Isn't it Ammonium Persulphate not Sodium Persulphate?
hugoender is offline   Reply With Quote
Old 20th June 2008, 02:50 AM   (permalink)
3v0
Originally Posted by hugoender View Post
As far as using Sodium Persulphate instead of Ferric Chloride... what are the pros and cons? There must be a downside to using Sodium Persulphate since everyone seems to suggest using Ferric Chloride.
Maybe the cost. It is about $20 kg. Having said that I make more boards the most hobby types and I am still on my first kg. Both do the same job. Ferric Chloride has a lot of momentum in that it has been chemical of choice for a long time. It is not surprising to see that most people still suggest it.
There are many people who do just fine with a clothes iron. There are also many people who do not. With the laminator you do not have to figure out how hot to make it or worry about how hard to press down. There is a tips section on the pulsar website. One guy suggested using a wood dowel rod under the PCB when ironing. It simulates the action of a laminator. I have not tried it but it sounds good. There may also be a section on how to set iron temperature.
Old 20th June 2008, 03:18 PM   (permalink)
Going back to the PICs... I am debating whether to get the PICKit2 Starter Kit ($49.99) or just get the PICKit2 Programmer by itself ($34.99). What do you guys think? Is the start kit worth the extra $15.00 or can I learn just the same without it?
Old 20th June 2008, 09:22 PM   (permalink)
For $15 extra the board that comes with the starter kit is nice.
speakerguy79 is offline   Reply With Quote
Old 4th August 2008, 05:37 AM   (permalink)
Well I made my own dual power supply and logic probe. Saved a lot of money not having to buy those two things... although I do not think a logic probe is necessary. A multimeter can carry out the same function.
where to buy test equipment notwist General Electronics Chat 5 30th March 2008 09:37 PM
How best to use US equipment in the UK nicka2604 General Electronics Chat 9 15th December 2007 04:38 PM
Test Equipment abbarue General Electronics Chat 3 10th November 2007 04:59 AM
Lab Equipment burg General Electronics Chat 7 30th June 2007 03:33 PM
A contest for Indian Robot hobbyists instruite Robotics Chat 0 3rd July 2006 01:52 PM
