| Oh and solder... it is a lot more expensive than i thought!!! I believe I already know exactly what solder I want (25-32 mil diameter with 63 Tin/37 Lead composition) but I don't know where to buy it and what are normal prices for solder. If you guys could let me know where I can find solder at good prices and how much solder goes for I would greatly appreciate it. | |
| I would get one of those irons with temp control. Anything else will not serve you as well. | |
| As you have some people that suport you in your buys (pressents) buy a good meter (fluke) and a cheapo as a second one buy a weller or a hakko soldering unit (you might consider a desoldering unit if you want into the repair business) build your own power supply build your own function generator start building things and learn your start set up is good Robert-Jan | |
| I'd also advise putting up pictures or calendars of semi nude, voluptuous babes. that'll brighten up the shop. and a fridge for beer and soda and a tv and xbox 360! and if you have cash to blow like those MIT alums, a maid! | |
| I bought one of these a few years ago Circuit Specialists Inc. - CSI Deluxe Station w/Analog Display (CSI-STATION1A) mine is a slightly different model though. Havent had any problems with it. I've just made sure to keep the tip clean and tinned and I never went too crazy on the temperature for long periods of time. I also made sure to shut it off. Also, dont wait to get those little drawer organizers. I waited about 6 months til I got my first set. by then I had too many components to organize.
__________________ Jeff Zimmerman To the optimist, the glass is half full. To the pessimist, the glass is half empty. To the engineer, the glass is twice as big as it needs to be. | |
| Although a little mundane, does anyone have any recommendations for sets of small drawers for organizing components? Maybe 100 drawers, each 2 or 3" in width. Possibly a variety of sizes. Also, I recommend the Hakko 936 soldering station. I've not destroyed any components yet, and the tips are nice to work with. Last edited by astronomerroyal; 17th June 2008 at 06:17 PM. | |
| Akro-Mils 64 drawer storage unit. This is definitely the one to get. $30 online. Unbreakable polypropylene? drawers. .5" x 1.75" address labels fit the front of the drawers perfectly. I can put 3 lines on a label using MS word and the label printing function. Part name (1N4002), MFG part # (xxxx), and Supplier. I have one and plan on buying another. Techni-tool has the best prices on solder. I like Kester 44 in 63/37 core 66 in .025 or .032 for through hole stuff, and .015 for surface mount stuff. OH! And an absolute MUST HAVE is a DS017 'Soldapult'. Do not buy any other solder extractor pump. This is the only one you will ever need. Last edited by speakerguy79; 17th June 2008 at 09:35 PM. | |
| SOLDER STATION TEMPERATURE CONTROLLED-MPJA, Inc. I have one of those. 40 bucks, comes with an extra heating element and the handlers are only 13 dollars. You won't find much cheaper that is temperature controlled.
| Even for bulk desoldering it pays to have a temperature controlled iron, avoids really bad oxidation when the iron is sitting idle and heating up WAY past usable limits, exposed to atmosphere at those kinds of high temperatures (idle a 40 watt iron without limit should hit 800F (425+C) with no air running across it) metals will oxidize rapidly, even stainless steel. Best case scenario is the iron over time will insulate better than it conducts and becomes useless as a soldering device. Worst case is it insulates well enough to set itself on fire. Stupid user error (me) even cracked the ceramic element of my MPJA unit because I screwed the handle on too hard and the thermal expansion cracked the tip of the ceramic off (stripped the handle screw as well) I cheated a bit trying to postpone putting in the new element and used a tiny dab of heatsink paste to relink the broken tip and it's still holding on just fine. Wondering if I should try coating the entire element and inside iron with a thin layer of heat sink paste to increase the thermal bonding, give it a little expansion room etc... Anyone ever done that before to an iron? Ideally you want the heating element, temperature feedback and 'load device' AKA tip in the same package anyways, even thin layers of air (JUST like a CPU) will cause localized over/under heating, a thin layer of thermal paste seems natural to me? The MPJA units the ceramic is the heater/feedback connector, the failure point seems to me to be the ceramic to iron interface, I don't think simple physical pressure is enough, especially with ceramic (ungiving) to metal (ungiving)
__________________ "Because I be what I be. I would tell you what you want to know if I could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." Last edited by Sceadwian; 18th June 2008 at 03:26 AM. | |
| I seriously think a good soldering setup is one of the best things a hobbyist should buy first. I've already bought a 20 dollar crapshack special which the casing has actually warped due to overheating (another good reason to temperature control) and the MPJA unit at 40 dollars. I've also picked up a 20 dollar hot air gun (read mini hair dryer, I've already had to bypass the internal one shot thermal cutoff trying to raise the temperature another 20 degrees (blocking air inlet)) That's pretty fringe. I think I should have just dropped the 200 bucks or so for one of the MPJA (Ebay also has a few units worth looking at) hot air + temp soldering iron centers. I think I might have more fun building my own hot air tool when I find I truly need one. The mini blow drier will work till then, much like the 40W soldering iron will work till I need a 100 watt one. Then yer talking 500+ dollars for a solid station.
The sponge is giving up the ghost. No problems. At some point I will get a hot air station. MPJA will be in the running.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) | ||
| Thank you very much speakerguy... your suggestions were great! They do indeed have the best price on solder (at least better than anything else I found) and those storage shelves are indeed pretty awesome. Much thanks. | |
| hmm... the MPJA site seems to be down. Is this temporary or are they out of business? | |
| temporary, as I just visited the site. I would go for a adjustable iron, but do not have it set to max temp when you are soldering temp sensitive parts (Laser diodes sheesh). | |
| where to buy test equipment | notwist | General Electronics Chat | 5 | 30th March 2008 10:37 PM |
| How best to use US equipment in the UK | nicka2604 | General Electronics Chat | 9 | 15th December 2007 05:38 PM |
| Test Equipment | abbarue | General Electronics Chat | 3 | 10th November 2007 05:59 AM |
| Lab Equipment | burg | General Electronics Chat | 7 | 30th June 2007 04:34 PM |
| A contest for Indian Robot hobbyists | instruite | Robotics Chat | 0 | 3rd July 2006 02:53 PM |
