Old 13th June 2008, 04:03 AM   (permalink)
Default Building a ripple control controller for hot water
In NZ we face a power crisis this winter, and they may take action by turning off our hot water cylinders to try and save power. If this happens, i want to be able to make a device that puts a signal in the range of 175 Hz to 1050 Hz, superimposed on the 50 Hz mains , 230v.
How easy would this be to do, as i dont want to be left without hot water!
nzoomed is offline   Reply With Quote
Old 13th June 2008, 05:10 AM   (permalink)
Are you saying you want to try and circumvent the turn off signal by adding your own signal to reactivate the valve? Hmm... Sounds illegal.
Mikebits is online now   Reply With Quote
Old 13th June 2008, 05:16 AM   (permalink)
Hi nzoomed
What are hot water cilinders ??
tanks with water and a heater element
there are other ways to make your water hot
but how would the goverment be able to switch of your hotwater generation in your house without effecting other parts of your system?
Robert-Jan
rjvh is offline   Reply With Quote
Old 13th June 2008, 06:26 AM   (permalink)
Default not illegal as far as im aware
because most power company customers chose to have it in the past, but in this country, it seems all new homes have it nowdays.
Originally Posted by rjvh View Post
Hi nzoomed
Robert-Jan
The reason why no other things turn off is because there is a receiver in your meter box, that receives the signals sent down the power lines from the power company which triggers a relay to turn off your hot water cylinder, nothing else is affected through this, we hear ours clicking at least once or twice a day that i can think of, usually in the mornings and evenings
Old 13th June 2008, 06:33 AM   (permalink)
Is it not easyer to over ride the contacts of the relais with a seperate switch
Robert-Jan
Old 13th June 2008, 06:52 AM   (permalink)
Default yes it would be
but thats tampering with the meter box, and if the power company found out, well they charge you to get it fixed if they found out
Old 13th June 2008, 07:37 AM   (permalink)
Is the hot water cilinder also sealed by the electricity company so you can't get the wires from the heater element and switch it by your self??
Robert-Jan
Old 14th June 2008, 02:07 AM   (permalink)
Default no it is not sealed
if i really wanted to i could wire a direct feed to the cylinder, so that it always got power, if they start cutting off hot water, i could easily do that
Old 14th June 2008, 02:54 AM   (permalink)
The first sentence of your post is "Power crisis" and you want to bypass it? The more people like you there are the more brown outs and blackouts there are going to be.
straight answer, har har."
Old 14th June 2008, 04:06 AM   (permalink)
Why not add another layer of insulation to your hot water cylinder. A well insulated cylinder will stay hot for days.
Pommie is online now   Reply With Quote
Old 14th June 2008, 09:39 PM   (permalink)
Default powercrises.
Hi nzoomed, welcome to this forum.
I'm not going into details about this topic but the solutions are already given in the replies.
The NZ powercrisis is a con, we need one so we finally get some proper power stations built. e.g. nuclear or coal fired, north of Auckland.
Our politcians have wasted mega dollars on windfarms which cannot guarantee a reliable supply to the city.
Regards, Raymond
RODALCO is offline   Reply With Quote
Old 15th June 2008, 01:32 AM   (permalink)
Default thanks your right
it is a big con, and ive found other way around it anyway, like thumping the meter i was told will trigger off the relay! lol but i still think it would be real neat project if you could make a controller that sent a signal down the mains! I dont know if it would turn off everyones hot water in your street though. ive seen networking kits called homplug that could send data signals through the mains for connecting your computers together, and that is supposed to only be able to work in your house.
Old 15th June 2008, 06:15 AM   (permalink)
I have been "Experimenting" with a circuit that works principally on the same way. Superimpose a frequency on the domestic AC lines and with a NE567 PLL detector on the receiving side filter out the correct frequency and use it for control. The problem I have is that it works 100% on static lines (while testing) but the moment I connected it to my AC at home, it tripped the earth leakage and I have an equipment failure rate of about 50% That's BAD!!!! (It either blows the transmitter IC or the receiver IC). And that's where I left it.
The circuit uses the Earth and Neutral wires on the AC circuit for its communication medium. The problem is (I don't know if all earth leakage devices does this, or just mine) the moment I superimpose the frequency (at about 5V) the Earth leakage picks it up and trips out everything.
SPDCHK is offline   Reply With Quote
Old 18th June 2008, 01:16 AM   (permalink)
Default we dont have an earth leakage device
in our house, only a circuit breaker or a fuse, which will blow if there is a short to earth, but that only works at close to full mains voltage to earth, ours has tripped over when ive had appliances short to the earth
Old 18th June 2008, 01:30 AM   (permalink)
it wouldn't hurt to have one in my opinion but personaly i have on a sertain group a higher trip current (due to conected equipment (welder))
still its safer than having nothing and they're not that expensive anymore
Robert-Jan
water level controller neelam29 General Electronics Chat 5 13th August 2008 10:08 AM
Water Tank level reader and pump Controller Osman Electronic Projects Design/Ideas/Reviews 15 9th May 2007 09:44 PM
water heater with temperature controller jemilsan Electronic Projects Design/Ideas/Reviews 27 1st March 2007 06:13 AM
Need Help Building A Fan Controller Frosty_47 Electronic Projects Design/Ideas/Reviews 13 8th October 2006 04:39 PM
Water level Controller Project TB Electronic Projects Design/Ideas/Reviews 2 11th May 2004 03:28 AM
