I have a 9V battery and i want to turn on a microcontroller. I am using LM7805 as a voltage regulator. what caught my eye is why i need to use capaciter ??
I tried without capaciter and it work! The thing that amaze me is the suggestion of manual LM7805 to use capaciter. See diagram below
Hesham Ismail Mohammed Sharif Thank me if you want |
Some of the older 780X Vregs can go unstable under certain conditions, the low value caps are there to prevent the instability, I would recommend you fit them.
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ |
Use the capacitors. I was using a 7815 voltage regulator without them one time. Sure enough I got 15V out of it when I was using a multimeter, but when I hooked up an oscilloscope it showed there was a large AC voltage superimposed on the 15V at a frequency of just over 1MHz. A multimeter will never catch anything like that. The data sheet for this specific regulator said it didn't need any capacitors, but when I put an output cap in there the high frequency oscillation went away.
7805's rely on the low output impedance of the emitter of their pass transistor to ensure stability. That impedance is not something that should be relied upon to be 'low enough'. Use a capacitor. 0.1uF ceramics are cheap. |
A 7805 voltage regulator needs a minimum input voltage of 7V.
But a little 9V battery's voltage quickly drops to 7V so its life will be very short. You should use a "low-dropout" 5V regulator that still works fine when the 9V battery's voltage drops to 5.5V.
Uncle $crooge |
I have a doubt on this. When a 9V battery drops to 5.5, where is the capacity in the battery to deliver power, even if the LDO regulator accepts the input and tries to give 5V DC as output?
Regards, Sarma. |
Hi Sarma,
The internal resistance of an alkaline battery increases which causes its loaded voltage to drop. Then a low dropout regulator simply turns on more to keep the regulated output voltage at 5.0V. If the load current increases then the voltage from the battery drops. If the load current decreases then the voltage from the battery increases. Here is a graph of the loaded voltage dropping from Energizer's 9V alkaline battery:
Uncle $crooge |
Trust the datasheet. The people who wrote it know more about the 7805 than you do. Torben |
You should be reminded that the microcontroller also needs its own capacitor from 5V to GND. This may be in the µC data sheet, but even if it isn't shown it is needed.
Don't forget that there is the low-power version in a TO-92 package, the 78L05, which takes up a lot less space and may consume less overhead power. It's rated for 100ma maximum.
Dean
Dean Huster, Electronics Curmudgeon Contributing Editor emeritus, "Q & A", of the former "Poptronics" magazine (formerly "Popular Electronics" and "Electronics Now" magazines). R.I.P. |
(permalink) | ||
--- The days of the digital watch are numbered. --- |
With 60% of your batt power being lost as heat in a linear reg. This little guy looks pretty cool.
http://www.perel.fi/pdf/dms-78xxsr.pdf Last edited by Mikebits; 12th June 2008 at 04:46 AM. |
I recommend the LM2936Z-5, it only drops 200mV, has a low quiescent current 15µA, it's cheap, robust and reverse polarity protected.
The only downside is it's only rated to 50mA but if you want more than that, then use the unregulated supply and you shouldn't really be using a 9V battery if you want more than 50mA anyway.
I personally have been using the LM2940, as it can drop to 5.6VDC (off the top of my head).
| 1.5A LM7805 substitute? | blueroomelectronics | Datasheet/Parts Requests | 15 | 4th February 2008 05:48 AM |
| Is there a 3.3V replacement for the LM7805? | William At MyBlueRoom | Datasheet/Parts Requests | 8 | 10th November 2006 12:49 PM |
| Negative LM7805 | computer | General Electronics Chat | 3 | 17th July 2005 10:07 PM |
| LM7805 smoothening capacitor | Spectacular Butter | General Electronics Chat | 8 | 5th March 2005 12:38 AM |
| LM7805 in Eagle PCB | computer | General Electronics Chat | 23 | 11th January 2005 07:54 PM |
