...I blow the dang fuse.
Remind me to use different color jumper wire for power and ground next time. It took the brunt of a 12V unregulated wall-wart. I'm hoping the fuse is the only thing that went. |
At least it wasn't across the 110V line.
Carl |
And fit the correct type fuse as specified by the manufacturer.
That will give you the correct interrupting capabilty in case of an other operator error and protects the meter. Your Fluke meter should be OK.
There are more ways to get to Rome. Electricity, Electric clocks, Meters and Trains are great. |
I've got the exact Fluke replacement P/N in my cart at Digikey. They're five dollars and change.
I don't know about flukes but all the meters I've seen use pretty generic 250mA fast blow cartridge fuses. I can't remember exactly what size, 25mm springs to mind though.
The Fluke fuse is Fluke PN 943121. It's manufactured for them by Bussman. The Bussman PN printed on the fuse is DMM-44/100, but searching that PN won't get you anything on Bussman's site or Digikey either. The only near equivalent I could find on Bussman's site is the Bussman DMM-B-44/100. My blown fuse looks identical to this one minus the "B".
Digi-Key - 283-2495-ND (Cooper/Bussmann - DMM-B-44/100) If you buy the Fluke PN (you have to search for it using Fluke's PN 943121) at Digikey it's 5.95. If you buy the DMM-B-44/100 it's $35. I put the Fluke one in my cart Last edited by speakerguy79; 13th June 2008 at 08:24 PM. |
It's $35 for a pack of 100, how many do you get for 5.95?
No they're really 35$ each @ Digikey. Standard package is the minimum package size Digi-Key receives from the manufacturer.
Hope the Fluke replacement is the same... 30$ less, that worth a try I replaced the same fuse in my own Fluke 189 awhile back... can't remember the price i paid though. Last edited by mister_e; 13th June 2008 at 09:58 PM. |
Yeah, this is for a 177. I wonder if the $35 fuse just has a different label or if the 'B' means something.
Oh, I see.
Digi-Key Help Screen That sounds a lot for a small fuse, some multimeters are cheaper than that.
Maybe a mistake somewhere, however, looking elsewhere for DMM-44/100 as part number, you'll find them for around 5$.. which is normal... better than 35$ that's for sure.
First Google hit Fluke Fuse DMM 44/100 > Fuse, 440 mA 1000V, 10x35mm, FA Fuse DMM 44/100 Fluke Test Equipment Allied Allied Electronics And so on. As speakerguy79 said, maybe the B mean something... Mouser sale them 20$... Last edited by mister_e; 14th June 2008 at 12:18 AM. |
Have you looked on eBay?
There again, this might be a bad idea is for safety reasons you want to avoid cheap Chinese crap.
If it were a cheaper meter I might, but saving a few bucks on a fuse for a $200 meter isn't my thing.
crustshow, 110 isn't so bad. I just blew a 7 amp fuse (and four diodes) when I plugged a bridge rectifier rated at only 1amp in backwards. Nearby light dimmed and there are some nice little metal balls (vaporized fuse wire that condensed) on the glass. Aside from the very mild audible pop that's what they're designed to do. The only reason I can think for a fuse being extra expensive is if the fuse itself is being used as the shunt for the current reading, but the only meter I've ever taken apart had an internal shunt seperate from the fuse.
could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." |
| How to measure transistor current? | menirva | Robotics Chat | 1 | 2nd March 2008 10:06 AM |
| Fluke 289 and Fluke 189 True RMS DMM's | Cifrocco | General Electronics Chat | 3 | 29th January 2008 01:11 AM |
| How to measure current ? | chanbkhn | Electronic Projects Design/Ideas/Reviews | 11 | 5th August 2007 10:40 AM |
| How to measure current using ADC? | StupidDum | General Electronics Chat | 8 | 18th November 2004 02:29 PM |
| design system to measure switching time of relays | guosen | Electronic Projects Design/Ideas/Reviews | 2 | 4th February 2004 05:51 AM |
