| PHAnderson sells LEDs with a built in current limiting resistor so you can connect them directly to 5V. These are very handy for use with solderless breadboards. I have been looking for another source as he only has them in red. The Newark site shows LEDs with Vf ranging from 1V to over 100V. If I buy one with a Vf of 5V am I getting a LED that does not require an external resistor to work at 5V? If the large Vf is not due to an internal resistor what is happening? A link would be sufficent on this last question. Thanks.
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) | |
Some white, blue and green LEDs have a forward voltage of 5V at high pulses of current. They need a higher voltage and a current-limiting resistor. Red LEDs are about only 1.8V.
| This LED is red. The datasheet lists Vf as 5V and does not say anything about using an internal resistor to get from about 1.8V which is normal for RED to the listed Vf of 5. So either REDs can have a Vf over twice what is normal or these have a internal resistor that drops the other 2.2V. Does anyone know which it is? I could order one and see if 5V with no resistor blurns it out.
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 11th June 2008 at 05:06 AM. | |
Maybe they included diodes or resistors on that same substrate?
Since the same LED is available in three versions (1.8V, 5V, and 12V) I would expect to see either a resistor or active current regulator.
| | #6 |
I have confirmed what mneary said. SSL-LX3044GD-5V — LUMEX — LED - Standard Forward Current:12mA Forward Voltage:5V Hooked directly between +5 and Gnd draws 11 mA according to my 20+ year old RS DMM. You can get them for about 25 cents at mouser or newark. Why do you care ? These things are great for breadboarding.
| | #7 |
hi, Its most likely a internal CC source of 12mA. You can also buy LED's that will work over a range of voltages without an external resistor.
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ | |
| | #8 | |
The range of voltages is what you can expect to see. If you feed 2.65V to an amber LED that has a forward voltage of 1.9V then it will burn out. If you feed 1.9V to an amber LED that has a forward voltage of 2.65V then it won't light. If you connect an LED with a forward voltage of 2.65V in parallel with an LED with a forward voltage of 1.9V then only the 1.9V one will light.
| | #9 | |
Hi, You can disagree, BUT I have bought and used them in my products. They have an inbuilt constant current source, so do not require an external resistor. IF you took the care to read my post carefully, you can see, I am not talking about standard LED's. EDIT: http://www.leddealer.com/Multi%20Vol...0Datasheet.pdf http://www.leddealer.com/newproducts.html Last edited by ericgibbs; 19th July 2008 at 06:30 PM. | ||
| | #10 |
audioguru is talking nonsense, you can get LEDs with buit-in resistors so i can't see why you can't get them with inbuilt current regulators. It's easy to make a current regulator, just tie a JUGFET's gate to its source and the manufacturer could easilly integrate this into the same package as the LED.
| | #11 |
Hi Eric, You posted a list of the standard typical forward voltage range of ordinary LEDs that need a current-limiting resistor added. Tese ordinary LEDs do not have a constant current source because their voltage range is the same as ordinary LEDs that do not have a constsnt current source. Here is a graph showing an ordinary red LED and what happens if it does not have a current-limiting device.
| | #12 | |
I posted that small chart of conventional LED's, as part of the ongoing discussion, for reference only. I appreciate that standard LED's will not stand a lot of abuse, I have used them a 'zillion' ways on 'zillions of projects. ![]() The easy way, is to use a low cost pnp transistor, a bog standard diode and a couple of resistors and make a 15mA CC source. It will drive the full colour spectrum of LED's quite happily from 12V thru 30v.
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 19th July 2008 at 06:56 PM. | ||
| | #13 |
If they listed internal CC regulation or internal resistor in the datasheet or the catalog I would not have started this thread. It looks like if the Vf is outside what you expect for the color it must have one or the other.
| | #14 |
The LUMEX datasheet is written in an old font like they use in Taiwan. It is very dim like old green LEDs used to be and then their forward voltage was half of this one. Therefore it has two LED chips inside (it has two bubbles on its bottom), each with a typical forward voltage of 2.5V (3.5v max). It might work from 5.0V without a current-limiting circuit.
| | #15 |
If you look at the Lumex catalog. http://www.lumex.com/mastercatalog2007.aspx The SSL-LX3044xD family of LED's can be ordered with or without an internal resistor which is an option. The -5V suffix most likely has internal resistor. There is also a -12V option. | |
| internal, large, leds, resistors |
| Large 7-segment LEDs | Dan East | General Electronics Chat | 1 | 1st February 2008 06:51 PM |
| Reprogramming PICs with Internal OSC on & MCLR disabled (internal) Inchworm+ | blueroomelectronics | Micro Controllers | 5 | 11th April 2007 05:10 PM |
| Really Large amounts of IO from PC | savage | Electronic Projects Design/Ideas/Reviews | 16 | 16th January 2006 02:32 PM |
| Question about LEDs and resistors. | tribaloverkill | Electronic Projects Design/Ideas/Reviews | 5 | 1st November 2004 05:55 AM |
| LEDs-Super Bright White LEDs $1.35USD ea | ssullivan777 | Datasheet/Parts Requests | 0 | 27th February 2003 03:02 AM |
