| What is the best size drill bit for regular hole through components...common resistors, IC sockets, and such? Thanks in advance! | |
| I use mostly .024" (#73) for most parts. If the layout is tight, and a part has really small leads I might go down to 0.018" (#77) but this is a pretty delicate drill. Sometimes a part has larger than normal leads so I keep a few larger drills all the way up to 0.0465" (#56). | |
| Ditto. I drill all my holes with a .024" bit. It is a bit sloppy for fine leads but still works. It is a tight fit for .1 pin headers but they go in. If in need a few larger holes I enlarge them with a bit in a pin vice or exato knife handle.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) | |
| Thank you! | |
| I always break those little suckers. So my default is #53 drill. | |
| Are you using a drill press or drill stand? They help a lot. Also if you can get non carbide bits they have a bit of flex in them.
| I tend to avoid anything as large as #53 because it's hard to get a good tent of solder between a .020" wire and a 0.059" hole. | |
| On Boards that I used to make & those that I contract out, I used a 0.8mm(31.496mil) hole for most parts (0.6w resistor, caps, 1n4148 etc) & 1mm (39.37mil) for (4004 diodes, 1W zeners etc..) This always leaves plenty of room for consistent solder wicking to the top side pad. However there are instances where I will make a hole a tight fit eg: single sided board & mechanically stressed (heavy) part, the close tolerance hole takes the stress away from the solder join. | |
| PC Drill bits | HarveyH42 | General Electronics Chat | 15 | 4th May 2007 09:22 PM |
| CPU PSU and 14.4V drill | Hank Fletcher | General Electronics Chat | 2 | 30th April 2007 06:48 AM |
| 12V PSU, 18V drill motor | Hank Fletcher | Robotics Chat | 9 | 27th March 2007 07:42 AM |
| carbide PCB drill bits | evandude | General Electronics Chat | 15 | 29th June 2005 05:24 PM |
| Drill xyz table | taday | Robotics Chat | 2 | 7th September 2004 08:51 AM |
