| Notices |
| | (permalink (permalink)) |
| Hi! The attached file is a schematic of 50KHz SMPS power supply which uses 325 VDC (after rectification of Mains 240 V). The required current is approx 15 Amperes. Please give comment if any modification in the circuit is required. | |
| Yes, as mvs sarma noted, the circuit has no regulation, either for input voltage or output load changes. If you can't tolerate poor output voltage regulation, then you will need to add a circuit to detect the output voltage and adjust the 3525 duty-cycle in a feedback loop. If you need output isolation, then the feedback will need to be through a transformer or opto isolator. | |
| The changes/modification proposed by the friends, and thinking that the half bridge topology is better for converting AC mains voltage to low voltage, the modified circuit is attached herewith with feedback control circuitry to keep the design stable. Please point out if any further modification is required. | |
| The modified schematic is attached in which both AC mains & secondary sided are separated by two different isolation symbols. the question is that the 0.1 ohms/10W resistor are sufficient to drive the transistor ( about 0.7v) or its value may be increased? | |
the wattage needed is 15*15*.05=11.25. So using 10 watt 0.1 ohms 2 nos would be safe enough. Finally whether it would limit at 15 amps or 10 amps , or higher depends on the voltage needed for the transistor (opto isolator) to switch. Later if needed, you may use a potentiometer of say 100ohms across the current sense and feed only a part of the drop to the transistor and it would help effective control of the current. How ever i have my doubts on ETD44 core -- whether it could deliver 15*16= 240 watts ( say 300 watts including the system efficiency). Try out better core with higher capacity.
__________________ Regards, Sarma. Last edited by mvs sarma; 11th June 2008 at 03:37 AM. | ||
the actual value can be around checked by you.
__________________ Regards, Sarma. Last edited by mvs sarma; 7th July 2008 at 12:16 PM. | ||
| i am amazed that no one has yet pointed out that you are applying 650V to a 500V FET. Try Digi-Key - IRG4BC20WPBF-ND (International Rectifier - IRG4BC20WPBF) or Digi-Key - 497-2785-5-ND (STMicroelectronics - STP9NK90Z) Either one would only require a single switch on each end | |
| in your original circuit I would use synchronous rectification: http://www.national.com/appinfo/powe...esigner112.pdf | |
| After receiving many criticism in the design, I have changed the design by using UC3842 Current-Mode PWM Controller chip. The data sheet is available with various manufacturer, while one page from Semiconductors - Integrated Circuits - Electrical Components is shown in the attachment. The schematic is then modified by me to fulfill my requirements. So, please point out if any further change is required. Both schematic (Original & modified are in the same attachment) | |
I for one, would feel, that we learn only by refining a design and not ny shifting ti another. I some criticises this design, would you, i wonder , change over to a third design. 3525 is also a good chip used many places . I saw them in telecom power supplies. BTW, if you are really interested how a critical review can be to improve a design, you should see one "improve a 0-30V lab psu from 3 amps to 5 amps, of course on another forum similarly you may see sensitive FM transmitter. both are from great AudioGURU. i really love the way he treated the topics, methodically and logically.
__________________ Regards, Sarma. Last edited by mvs sarma; 14th June 2008 at 05:15 PM. | ||
| is a smps ok for a pic | Thunderchild | Micro Controllers | 16 | 28th January 2008 01:19 AM |
| SMPS circuit | alfons | Electronic Projects Design/Ideas/Reviews | 3 | 20th January 2008 01:04 PM |
| AT 230W SMPS circuit diagram | shamikrudra | Electronic Projects Design/Ideas/Reviews | 5 | 6th July 2005 08:27 AM |
| smps circuit design its my project --> plz help | vejay_ece | Electronic Projects Design/Ideas/Reviews | 4 | 24th December 2003 09:41 AM |
| SMPS to SMPS | bogdanfirst | General Electronics Chat | 2 | 16th March 2003 06:44 AM |
