I looking at using a max232 and it show 2 charge pump caps. anything special about these or will any elect. cap the right size work thanks | |
| | #2 | |
Electrolytics are often used with no problems, use the recommended values with a 16Vwkg rating.
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ | ||
Hi, use the MAX233 - no external charge pump caps - same function. Everything is on board already. Boncuk | |
Yes that's correct. But you can get the 232 chip significantly cheaper, even including the price of the caps.
also, be aware that there is an A version (232 vs 232A) that uses smaller caps. I prefer the A since I can use ceramics.
| | #6 |
thanks so I guess my option are 232 with Electrolytics cap of the right value 233 no caps 232A smaller ceramic cap | |
| | #7 |
I've used monolithics quite successfully in at least 5 designs. Like any other charge pump, just make sure they're voltage-rated higher than your output voltage.
| cap, max232 |
| Which MAX232 to get!? | Marks256 | General Electronics Chat | 15 | 19th January 2008 09:39 PM |
| 3.3v MAX232? | Oznog | General Electronics Chat | 9 | 7th April 2006 01:59 PM |
| Pic to max232 to PC | 1Steveo | Micro Controllers | 5 | 31st January 2005 06:06 PM |
| MAX232 | ice-egoz | Micro Controllers | 1 | 30th July 2004 08:51 AM |
| MAX232..need help | cwt | General Electronics Chat | 1 | 18th May 2004 10:00 AM |
