+ Reply to Thread
Page 1 of 2
1 2 Last
Results 1 to 15 of 19
Thread: Need to Step Up Low Voltage
  1. #1
    VSnyder Newbie
    Join Date
    Oct 2003
    Posts
    4
    Default Need to Step Up Low Voltage
    I have a fuel cell that produces between .4 and .9 VDC, with current increasing as voltage decreases, max current of 2 A. This .4 volt, 2 ampere condition is the most powerful. I would like to use the fuel cell to drive a motor, let's say 6 V. Is there any way to step .4 V to around 6 V? Is there some way I could turn the steady signal into a wave, without using semiconductors (so that I can avoid the .6 V voltage drop) so that I can step up the voltage with a transformer? Thank you!
    --vsnyder@mines.edu
  2. #2
    laroche73 Newbie
    Join Date
    Aug 2003
    Location
    Ann Arbor, MI
    Posts
    414
    Default low voltage converters
    You may want to look at some of the robotic sites (BEAM), it's a similar situation with solar cell powered motors.
    This site has a few solar powered motors that might be useful for ideas:
    http://www.solarbotics.net/library/c...e_t1_gbse.html
    Can you run two of the fuel cells in series? You'll have more luck finding a conversion solution with a 0.8V minimum than with 0.4V. I recently did a similar search with solar cells in mind, and came across a nice line of LED drivers made by Zetex. The ZXSC3xx series will work off input voltages as low as 0.8V. I sent you a PDF of the datasheet.
    http://www.zetex.com/frame.asp?page=...link=spotlight
    both the Zetex parts and the 1381 mentioned in the first link can be found at digi-key.
  3. #3
    bmcculla Newbie
    Join Date
    Sep 2003
    Location
    California, USA
    Posts
    898
    You could build a DC-DC Step Up or Boost converter. THe LM3488 looks like a nice one for a good price. A DC-DC converter switches current through an inductor to generate an output voltage. Thay can be up to ~90% efficient and because they use a feedback loop to keep the output voltage steady you dont have to worry about the .7V drop you are talking about.
    Brent
  4. #4
    Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,721
    Quote Originally Posted by bmcculla
    Brent
    Yeah, except for the fact that the minimum input voltage is 2.95v.
  5. #5
    VSnyder Newbie
    Join Date
    Oct 2003
    Posts
    4
    Looks to me like the lowest input voltage I can use is .5 V with a synchronous boost converter, which has a maximum power output of half a watt. I was hoping for some simple way to use just a few capacitors or something to vary the signal (wave or pulses), so that I could use a transformer, which would put out all the power I put in. (As you can probably tell, I really don't know much about electronics.) If anyone has anyone suggestions, I would love to hear them. Otherwise, I'll go with the synchronous boost converter. Thank you for all the help, everyone!!!!!
    vsnyder@mines.edu
  6. #6
    bmcculla Newbie
    Join Date
    Sep 2003
    Location
    California, USA
    Posts
    898
    Thanks for the correction Ron
    Brent
  7. #7
    laroche73 Newbie
    Join Date
    Aug 2003
    Location
    Ann Arbor, MI
    Posts
    414
    Default low voltage dc-dc conversion
    What synchronous boost converter IC did you find that can start up and run off of 0.5V? Just curious.
  8. #8
    VSnyder Newbie
    Join Date
    Oct 2003
    Posts
    4
    Search for "synchronous boost converter" at www.digikey.com, and you'll see the list I've been looking at. Several claim to operate down to .5 V--not sure about the start-up, though....
  9. #9
    laroche73 Newbie
    Join Date
    Aug 2003
    Location
    Ann Arbor, MI
    Posts
    414
    Default start-up voltage
    The start-up voltage is usually higher than the minimum operating voltage. For the LTC3400, the worst case startup voltage is 1V (0.85V typ), and the worst case operating voltage is 0.65V (0.5V typ) @ 25C.
    The LTC3423 will work off input voltages as low as 0.5V, but needs a separate supply of at least 2.7V to operate its internal circuitry.
  10. #10
    VSnyder Newbie
    Join Date
    Oct 2003
    Posts
    4
    I suppose I could use that IC that requires a seperate power source for its internal circuitry, and power it with a watch battery. Am I correct in assuming that the more current I put into this IC, the more I'll get out?
    vsnyder@mines.edu
  11. #11
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,721
    Quote Originally Posted by VSnyder
    vsnyder@mines.edu
    You could power it from a rechargeable battery that is trickle charged by the output of your converter. Or, if you could start it on battery power then automatically switch over to powering it from the output with a diode OR as soon as the output comes up.
  12. #12
    laroche73 Newbie
    Join Date
    Aug 2003
    Location
    Ann Arbor, MI
    Posts
    414
    Default kick-start battery
    Not a bad idea. Panasonic makes a nice line of coin-cell rechargeable lithium batteries (3V), also available through Digi-key.
    http://www.panasonic.com/industrial/...h/manglith.htm
    here are some more notes on low-voltage DC-DC conversion:
    http://www.maxim-ic.com/appnotes.cfm...mber/364/ln/en
    http://www.maxim-ic.com/appnotes.cfm...mber/188/ln/en
    (Digi-key doesn't carry the MAX866, but they do have the newer MAX1678)
  13. #13
    laroche73 Newbie
    Join Date
    Aug 2003
    Location
    Ann Arbor, MI
    Posts
    414
    While we're on the topic of stepping up very low voltages (~ 1.5V and under), here's a simple open-loop boost converter I stumbled across. It works down to 1V, and uses a couple of 2N3904s.
    http://www.e-insite.net/ednmag/conte...es/70501di.pdf
    (scroll down to "Single cell lights any LED")
  14. #14
    thekingkisna Newbie
    Join Date
    Nov 2006
    Posts
    10
    Default equivalent to 1381
    can anyone suggest an equivalent to 1381... I asked the electronics storeguy and he gave me LM336 Z25. my circuit which is a beam solar photopopper. isnt working. can anyone suggest a site which gives equivalents or let me know if lm336z25 is really a good subsititute for 1381. search for 1381 solar engine, and thats the one that i m trying to make.
    thanks.
  15. #15
    Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,076
    Surely those converters don't require much current to operate the control circuitry which you can run off a couple of alkaline batteries.
    if I know the answer.
+ Reply to Thread
Page 1 of 2
1 2 Last
Tags for this Thread
