| I was setting up an evaporative cooler and I'm fairly sure my buddy got some water in the motor since it smoked and wouldn't turn while humming. After I opened it up and cleaned it out it seems to work fine, however, I was wondering if the waxy paper stuff and string used was application specific (heat tolerance?) or if I could just secure the wires with zip ties or similar? Thanks in advance! | |
| That is kind of a vague question. Zip ties are a consideration. Hot melt glue is another. John | |
| So pretty much anything that'll take ~110+F is o.k. to use? | |
| Your transformer is likely to be rated higher than 40°C. I would consider a higher melting wax -- they come in all temperatures up to several hundred degrees centigrade. Check the temp rating on your, or on similar transformers to decide what you need. John | |
| Will do. Thanks! | |
| Method to Make Project Panels (Warning: Detailed Info!) | crashsite | Electronic Projects | 36 | 14th September 2008 04:22 AM |
| First Time Making PCB: Suppliers, Hints, ETC | Souper man | General Electronics Chat | 22 | 9th June 2007 01:31 PM |
| toner transfer with silicone impreg paper | justDIY | General Electronics Chat | 28 | 13th March 2007 11:33 PM |
| PCB toner transfer | Badar | General Electronics Chat | 53 | 24th February 2007 10:10 PM |
| toner paper | nye | Electronic Projects Design/Ideas/Reviews | 8 | 27th October 2006 10:23 PM |
