Old 15th May 2008, 07:05 AM   (permalink)
Lightbulb CPLD (Xilinx) programming tutorial
How to start with programmable logic.
1. You'll need a PC with a parallel port (true parallel port, no USB adapters)
2. Download and install the Xilinx ISE Webpack from www.xilinx.com
3. get/buy/build the Xilinx Parallel cable III programming adapter
4. get a Xilinx CPLD, for example XC9572 in PLCC-44 package
you can also buy a PLCC-44 to DIP adapter (e.g. Aries, from DigiKey) and
use breadboard.
When programming a CPLD (or FPGA) you don't create a program but description of the logic that implements the desired functionality, usually using a hardware description language. I will use VHDL in the example.
Example #1: Implement a synchronous 4-bit counter with asynchronous reset and synchronous load (a little like a simplified 74161) signals active in '1', clock at rising edge.
Create a new project, select directory and top level source HDL, Next>
Select device (XC9572) and package (PC44) preferred language VHDL.
Then you can use the wizard to create a new source (mycounter.vhd)
and implement the logic - copy the VHDL code from below:
-- includes (common useful libraries)
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
-- tutorial: 4 bit counter design
entity Mycounter is
    Port ( reset 	: in  std_logic;		-- asynchronous reset
           clk 	: in  std_logic;     -- master clock input, active rising edge
           load 	: in  std_logic;     -- synchronous load enable
           data 	: in  std_logic_vector (3 downto 0); -- data to load if load is '1'
           output : out  std_logic_vector (3 downto 0)); -- output of the counter
end Mycounter;
architecture rtl of Mycounter is
	-- VHDL does not allow using output signals as input so I need this helper signal
	signal	myout: std_logic_vector(3 downto 0);
begin
	-- send out helper signal to the output pins
	output <= myout;
	-- this is the output signal
	cntr: process (reset, clk)
	begin
		if	reset = '1' then
			myout <= "0000"; -- reset active ...
		elsif rising_edge(clk) then -- no reset, so wait for rising edge of the clock
			if load = '1' then
				myout <= data; -- load was active so copy input data to the output
			else
				myout <= myout + 1; -- load was not active so count ....
			end if;
		end if;
	end process cntr; --- that's all
end rtl;
Then you can run the implementation (Menu Process/Run) and if everything is ok, a programming file for the CPLD is created. The only problem is we don't know which pins are the signals load, data ....
So let's add another file - User constraints file (.ucf) where we force the implementation to use specific pins for our signals
Click on the left side Create new source and select implementation constraints, name it MyCounter.ucf. Here is my selection of pins:
NET "clk"        LOC = "P5" ;
NET "data<0>"    LOC = "P1"  ;
NET "data<1>"    LOC = "P2"  ;
NET "data<2>"    LOC = "P3"  ;
NET "data<3>"    LOC = "P4"  ;
NET "load"       LOC = "P44"  ;
NET "output<0>"  LOC = "P12"  ;
NET "output<1>"  LOC = "P11"  ;
NET "output<2>"  LOC = "P9"  ;
NET "output<3>"  LOC = "P8"  ;
NET "reset"      LOC = "P39" ;
There are specialized pins optimized for clock input (GCK) and for global reset (GSR) so I used them, other pins I just chose what was conveninent ....
Now it is time to run implementation again and them to program the CPLD.
To program the programming file into the CPLD connect the JTAG pins of the CPLD to the programming adapter, power the CPLD and adapter (5V for XC9500 family and 3.3V for XC9500XL family). Expand the Generate Programming File and select Configure Device (iMPACT). Use the default options.
After programing the CPLD you can connect it on a breadboard and check that it performs the designed function - a 4-bit binary counter
Enjoy.
Petr
petrv is offline
Old 17th September 2008, 01:15 PM   (permalink)
Isn't it better to use some cheap USB JTAG interfaces such as http://www.jtagtest.com/ instead of building parallel port stuff ?
jonK is offline
Old 17th September 2008, 03:06 PM   (permalink)
The short answer is your cheap JTAG interface will not work unless made specifically for Xilinx CPLDs. Additionally the one you gave on that page is maybe affordable but at $119 is definitely not cheap - the parallel interface will cost you literally just a few $ if you build it yourself AND is directly supported from inside the development environment. Actually it should be possible to use a JTAG adapter supporting SVF format but this involves extra step (converting the jedec programming file to the SVF format by redirecting the output of the JTAG programmer to a file). If you really do not want to build the Xilinx JTAG parallel port adapter (which is really simple, just two 74HC125 and a few passive components) I can suggest to look at http://www.digilentinc.com they have a lot of interesting items for programmable logic (for example their NEXYS 2 board)
and also JTAG USB cable for $38 which supports Xilinx devices and also Atmel AVRs
http://www.digilentinc.com/Products/...ts&Nav2=Cables
BTW the Nexys 2 board already contains this adapter so if you own NEXYS 2 you just connect it via USB to your PC and install their software.
The reason why I have suggested the parallel port JTAG interface is that it is really the cheapest solution and the only one supported directly from the Xilinx development environment. The Xilinx USB JTAG is unfortunately quite expensive.
petrv is offline
Question about Inchworm+ Quan Micro Controllers 54 28th October 2007 12:20 AM
UNIT Committment solution using Dynamic programming arijit18 Electronic Projects 1 18th October 2007 08:27 PM
Programming languages sram General Electronics Chat 9 2nd March 2007 04:14 PM
Xilinx CPLD programming patroclus General Electronics Chat 6 5th October 2006 12:57 PM
static rams,xilinx,rockwell, and other components for sale spencer Datasheet/Parts Requests 6 21st August 2003 06:36 AM
