Experienced Member
Hello, I would like to know what alternatives there are to the use of step down transformer. Say, I needed to transform 120VAC to 24VAC and I have very high current requirement (30Amps as an example). The use of such transformer will be highly expensive + the overall weight and size of such transformer would be 2 impractical. What alternatives are there?
"The people who cast the votes don't decide an election, the people who count the votes do." -Joseph Stalin |
Experienced Member
Not many really...much else would be more expensive and lower capacity...but possibly lighter or smaller like a large boost converter. Though the size of the inductor might be very large anyways.
NO, that picture isn't me so don't bother asking if we can be friends. Last edited by dknguyen; 15th May 2008 at 02:08 AM. |
Experienced Member
If you don't need isolation between the 120vac and the 24vac you might consider an autotransformer. They are smaller and cheaper since they only have one winding (hence the lack of isolation). The voltage is tapped off the winding, sort of like a potentiometer.
Fixed autotransformers are not common but a transformer manufacturer may have them or can build one for you if you have the budget. A common variable autotransformer is a Variac. |
Experienced Member
One thing that I've done in the past was to use a 480/120 power step down transformer. Yes it's still bulky/heavy, but I needed a high current low voltage source like you. With 120v on the primary (480 terminals)you should get about 30v on the secondary...I don't know what the voltages are in your area, so this may not be possible...
gerty |
Experienced Member
You need to look at a switch mode power supply, although these will be very expensive, in larger sizes.
I fitted a 750 watts 240 / 24 Volts SMPS yesterday in one of our substations to support the scada system. That one is rated at 30 Amps. load was around 25 Amps initially, then tapered off to a steady load of 15 Amps.
There are more ways to get to Rome. Electricity, Electric clocks, Meters and Trains are great. |
Experienced Member
I can't think of an effcient method of generating 23vac at 30 amps that would not involve a transformer either in it's input stage or output stage if an invertor is tried. Lefty
Measurement changes behavior |
Experienced Member
If here were a cheaper alternate to a transformer for converting AC voltages, the power companies would be using it.
Experienced Member
There must be some kind of educational deficiency out there because this question keeps coming up and the answer is almost always the same.
We never have time to do it right; but we always have time to do it over. |
Experienced Member
I agree with PapaBravo on "Education Deficiency" as really none of my professors or any electrical people I know seem to have an answer for this. I tried studying switching PSU's however; I found no mention of this topic. Switch mode are basically more efficient but they still require a stable DC input voltage in order to work thus the need for transformer again.
What about Computer PSU's ? Mine is ratted for almost 80A combined and hell, there are no bulky transformers inside of it. Just a few bifilar chokes, inductors, and one very weird, multi-winding, tiny transformer that I would give no more than 1A ratting... Any more ideas any one? I am seriously fed up with google giving me bunch of useless crap that’s non-related to the desired topic... Thanks
Experienced Member
Experienced Member
Experienced Member
Like look at this S41t ! This is the kind of garbage I get when I type in "Transformer Alternatives" in google. Here is the very first result:
http://thetransformer.us/ These morons don't even know what a transformer is yet they name their site with it. Wish those people who registered the above domain, get hooked up to the secondary of a microvave oven transformer for a period T --> ∞
"The people who cast the votes don't decide an election, the people who count the votes do." -Joseph Stalin Last edited by Frosty_47; 16th May 2008 at 03:36 AM. |
Experienced Member
Sorry, I am not trying to go down hard on you, I just realy whish to know more... If you know any good articles, can you please provide a link... Thanks
Super Moderator
Essentially they rectify and smooth the mains, giving 320V DC in the UK, in the USA they usually use a voltage doubler to give a similar DC voltage. This voltage is then chopped at a high frequency (between roughly 15KHz to 100KHz) and fed to a very small transformer, the output of the transformer is rectified and smoothed, where you can use MUCH smaller capacitors because of the higher frequency. The output voltage is monitored, and correction signals sent back to the chopper to alter it's mark/space ratio and keep the output constant. Incidently, the worlds first domestic use of a SMPSU was in the Thorn 3000 colour TV about 1972 or so?. |
Experienced Member
The physical size of a transformer is governed by its losses, not the power that is "transformed" from input to output. Losses typically consist of resistive, eddy current & core (magnetic). Controlling these in your design will determine your maximum power rating. A typical "offline" switchmode converter will first rectify and smooth the line thus creating a high voltage DC. From there, a PWM method is used on a flyback transformer to generate the right output (typically) |
| Transformer Advice Required | codan | General Electronics Chat | 7 | 21st April 2008 03:33 PM |
| Transformer Question | firealarmfreak | Electronic Projects Design/Ideas/Reviews | 5 | 3rd March 2008 01:39 PM |
| Problems selecting a PCB Transformer | NewcastleSAR | Datasheet/Parts Requests | 31 | 4th January 2007 07:15 PM |
| Transformer Alternatives? | jamesdedogs | General Electronics Chat | 11 | 28th September 2005 08:10 PM |
| Differential transformer how to measure this signal | sardineta | Electronic Projects Design/Ideas/Reviews | 18 | 7th October 2004 02:30 PM |
