| Experienced Member | Hello, My prof gave me a homework assignment regarding offset nulling. I know how to null using the provided offset null pins however the hmw question asks on how to null a non-inverting op-amp that does not have offset-null pins. In inverting amplifier, nulling can be achieved by connecting a resistor (that must be = Rf || Ri in value) in series with GND and the non-inverting input. But, how should I connect the resistor to achieve the same thing in the non-inverting configuration? Thanks
__________________ "The people who cast the votes don't decide an election, the people who count the votes do." -Joseph Stalin |
| Experienced Member | Quote:
Lefty
__________________ Measurement changes behavior | |
![]() Thanks
__________________ "The people who cast the votes don't decide an election, the people who count the votes do." -Joseph Stalin | |
As far as values for the input resistors if you just do searches on summing op amps you should be able to find a source for the calculations needed depending on the input voltage range and the desired gain of the circuit. Lefty
| Experienced Member | Adding a voltage to the non-inverting input affects the gain of the opamp because it is an attenuator. The inverting input of an opamp is its summing input. Adding a positive or negative current with a pot for nulling won't affect its gain.
__________________ Uncle $crooge |
Thank you
| Experienced Member | The current through the offset adjust pot plus in the series resistor is an input into the inverting input of the opamp. The ratio of the feedback resistor to these totaled resistances is the calculation for how much offset voltage is produced.
Lefty
| Experienced Member | Just use an opamp that has its input offset voltage adjusted to a very low voltage at the factory.
Thank you
| Experienced Member | Can't you read? The datasheet for the OPA454 says its input offset voltage is typically 0.2V (pretty good) but could be a max of 4mV (like most ordinary opamps). It changes more when the temperature changes. The range is so wide that it is not adjusted at the factory.
Thank you for your help and time
| Experienced Member | The input offset voltage of an opamp is amplified by the voltage gain of your circuit. The input current and input offset current also adds an offset voltage,
| Experienced Member | Hi Roff, adding or subtracing a current to/from the inverting input of an opamp does not affect its voltage gain because the inverting input is a "virtual ground".
| crossover disturtion in Op Amp | froten | General Electronics Chat | 11 | 13th May 2008 05:30 PM |
| how can i stop my car subwoofer amp from "motorboating"? | haskellbob | General Electronics Chat | 7 | 5th May 2008 10:41 PM |
| Amp wanted | spuffock | General Electronics Chat | 4 | 12th November 2007 12:25 PM |
| Clamp output of op amp | dazza000 | Electronic Projects Design/Ideas/Reviews | 21 | 9th November 2007 08:31 AM |
| PA Amp; noise reduction help | CrazyOldGuy | Electronic Projects Design/Ideas/Reviews | 3 | 18th September 2007 04:46 PM |
