Experienced Member
hello every one i have a weller SP23L 25watt soldering iron. it is great for what i am doing not but i need new tips bad i was looking to buy the tips off this site.
http://www.action-electronics.com/weller.htm or any other site i also need some 60/40 solder and tip tinner/cleaner basic stuff i just cant find tips for it and i need then badly. thank you |
Experienced Member
Are you saying that you can't find tips at the website you listed? I believe I located the listing of spare tips at your original posted website. Look about halfway down the page, they are listed at the end of the ad for your iron(they come in pairs it says).
http://www.action-electronics.com/weller.htm#Sp23 |
Experienced Member
they have the cone tips but any others.
and what about the Polishing Bar for your tips the info Polishing bar cleans and renews soldering tips Removes plastic resins, oxidation, silicone grease from tip Re-tin tip after use to prevent oxidation |
Experienced Member
In the olden days before iron / nickle plated tips, well that is another story. |
Experienced Member
Use 63/37 instead of 60/40. It melts at a lower temperature and solidifies better (metallurgically).
Experienced Member
I don't think the cheap soldering iron has temperature control. It gets so hot that it cooks and chars the rosin in the solder which is not cleaned by wiping with a damp sponge which also might cook and char.
Uncle $crooge |
Experienced Member
Soldering irons that are not temperature controlled get very hot, like 750-850F. Even little 10W irons will get this hot, it just takes them longer to get there. At those temperatures you run into problems with the tip oxidizing and the flux burning off instead of melting (litlle white puffs of smoke, anyone?)
I could never keep one of these little guys clean for more than 4 or 5 minutes at a time. The oxidation that builds up is tough to get off and, even when you do, comes back in no time at all if the iron is left sitting idle. By the time you pay for a couple of cheap tips and shipping, I'd rather spend a bit more and get a cheapy temp-controlled station. I've seen them in the $40-$50 range at places like MPJA and Howard Electronics. Make double-sure it's a temperature-controlled station not a "power-controlled" one. My first cheapy station used a triac to adjust the voltage to the tip and wasn't worth a damn. Like I said before, even at low power, the tip will eventually heat up too much. |
Experienced Member
Weller sells 600, 700 and 800 degrees F tips for my soldering station. I tried them and selected 700 degrees. Cheap soldering irons without temperature control get much hotter, maybe as hot as 1500 or 2000 degrees F.
Uncle $crooge |
Experienced Member
Experienced Member
So a cheap soldering iron vapourizes the flux in solder and welds the wires together with its very high heat.
Uncle $crooge |
Experienced Member
ok well i got quiet a few tips for this iron but my bday is in august so i will get a good soldering station. any good ones in mind i think in the range of 50 to 70 USD would be good for now maby more i will have to see how this lawn mowing biz goes
Check this one out:
Xytronic 379 I have the model just above that one, a 137ESD, that basically just adds a digital temperature readout and it's been a great little iron. |
Experienced Member
My Weller soldering station keeps the temperature of the tip constant. It doesn't have a temperature adjustment (the tips are selected for different temperatures) and it doesn't have a display. It is at least 42 years old and the same one is made today.
Uncle $crooge |
| Soldering tips for tiny connectors | radiodude | Chit-Chat | 10 | 19th May 2008 04:24 AM |
| Basic Soldering & Desoldering Guide | ElectroMaster | Electronic Theory | 13 | 3rd October 2007 04:54 PM |
| Soldering iron, you're FIRED! | mstechca | General Electronics Chat | 15 | 4th April 2006 09:51 PM |
| Soldering iron questions | moody07747 | Chit-Chat | 29 | 14th February 2006 12:17 AM |
| How to properly take care of soldering tips? | rvk2 | General Electronics Chat | 11 | 28th August 2005 09:41 PM |
