is there a way of trying to find out what IC is in an particular circuit i have, the IC at the top has been rubbed so cant see what it is? Is there anyway? its only a small circuit with a few zenors, caps and resistors with 3x c1815 transistors which are .. AUDIO FREQUENCY AMPLIFIER HIGH FREQUENCY OSC NPN TRANSISTOR and this one IC the ic itself is 14 pin, and pins 4 is linked to 12, 5 is linked to 11, and 6 is linked to 10 if that helps? |
As you don't even mention what the circuit does, how can anyone make any possible guess?.
basically, its a small box unit, which you then plug inline with a stock ECU unit for an active spoiler on a car, on the car the active spoiler unit has a button that you can press to manually make the spoiler come down but only when the car has power but not started so last key turn before starting car, but with this unit, it allows you to manually control the active spoiler from that switch even when its running, as the only other time the active spoiler comes down is when you go above 60mph, and then goes back up once dropped below 60mph.
here are a couple of pics if that helps at all??
(Example: to Ignition Switch, Ground, etc.) Also show all IC Pin Connections.
I No Longer accept Private Messages on here. All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\" or they go Directly to my Junk Mail Folder. Email me at: chemelec@hotmail.com Website: http://www3.telus.net/chemelec |
From the way you describe its hookup, it could be a bridged dual-circuit device ( op-amp, comparator, amplifier, regulator or generator) or a transistor package.
Is there a model number or brand on the PCB that we might be able to find the service manual for?
Doubt it, but it's worth a try.
What is a joule per second? |
One way I use for hard to read ic code lettering is to lightly breathe on the ic, so that a fine mist forms on the ic surface. Tilt the ic at different angles under a bright light, quite often the lettering becomes visible for a while. I know it sounds disgusting, but it often works. Also used the same method on old radio/TV valves [tubes to our American cousins].
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ |
| Identifying motors | ssylee | General Electronics Chat | 9 | 18th January 2008 10:54 PM |
| Help needed identifying part | Timmymna | Datasheet/Parts Requests | 4 | 24th September 2007 08:47 AM |
| Help required identifying a manufacturer's logo. | billyboy2 | Datasheet/Parts Requests | 14 | 23rd April 2007 07:25 PM |
| Help identifying component and alternatives | Alter | General Electronics Chat | 3 | 17th February 2007 03:04 PM |
| Need help identifying sensor / signal on motorcycle. | Phoenix | General Electronics Chat | 3 | 7th May 2003 08:32 PM |
