Old 10th May 2008, 08:58 AM   (permalink)
Default FSK Baud rate
hi
any one can explain the relation between carrier freaquency " RF " and the data Baud rate It can handle using FSK technique.
Examplr : If Ihave 50 MHZ FM transmitter the how much BAUD RATE can it handle using FSK ,
BR
khgsm2007 is offline
Old 10th May 2008, 09:04 AM   (permalink)
What RF module are you using?
The 50Mhz is most probably the spectrum the modules are using, not the baud
Spency.
PIC Micro's - Your mind is the limit
PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net
gramo is offline
Old 10th May 2008, 10:26 AM   (permalink)
hi
Please Just forget about ready RF modules , i am dealing with a small FM transmitter with few Millewatts , i want to send data using this 50 MHZ transmitter using FSK , theoritcally in FSK the zeros & ones will deviate the 50 MHZ to some additional KHz
what iam asking for is the limit of data baud rate " Kbps " i can send / rescive using the 50 mhz RF carrier
Thanks alot
BR
Old 10th May 2008, 10:38 AM   (permalink)
Originally Posted by khgsm2007
hi
Thanks alot
BR
In that case, wouldn't it come down to the encoder/decoder your using, and its relevant data sheet?
Spency.
gramo is offline
Old 10th May 2008, 10:51 AM   (permalink)
hi
whats up with encoder / decoder ??!! , what Iam asking
is just the realtion between modulating " abud rate " & modulated " RF frequncy" can I send 1000 mega bit per second data for example ??!! or there is alimit of data rate considering the carrier Rf , data rate , modulting technique ... etc
BR
Old 10th May 2008, 10:54 AM   (permalink)
Essentially the lower the frequency the lower the baudrate, simply because higher baudrates take more bandwidth.
Nigel Goodwin is online now
Old 10th May 2008, 12:35 PM   (permalink)
In theory you could use 100 MHz of bandwidth centered at 50 MHz. There would be some problems with this approach however. Not the least of them being creating an antenna and a receiver to cover that range. An analog television channel is 6 MHz. and an uncompressed digital channel supposedly takes 10-12 MHz. These seem like practical limits for information transfer over an RF link regardless of the modulation method. On the digital channels they now make use of compression algorithms to cram more channels into the same bandwidth.
We never have time to do it right; but we always have time to do it over.
Papabravo is offline
Old 10th May 2008, 01:42 PM   (permalink)
thanx alot for good info.
BR
PIC 18f1220 EUSART Baud Rate Cache Problem wklose99 Micro Controllers 7 16th April 2008 11:37 PM
Software serial baud rates Oznog Micro Controllers 1 3rd May 2005 08:20 AM
Baud rate transmission problem Spectacular Butter General Electronics Chat 18 24th February 2005 10:30 AM
Baud rate and frequency Spectacular Butter General Electronics Chat 5 6th December 2004 08:26 PM
Setting Baud Rate for Modem connected to 89c52 ????? Yatin Electronic Projects Design/Ideas/Reviews 1 13th September 2004 11:11 AM
