| If I may, could I please revisit a beginner's question from 12.Mar.2008? Please find attached sketches of two circuits, before and after. The "after" picture encorporates changes suggested by on1aag, which: 1. changes the "after" circuit to stop the pump at temperatures above something set by P1 (140 degrees F, in my case); 2. smooths hysteresis; and 3. uses an IRF540 (or similar) MOSFET to switch on/off a 12VDC 500mA pump, where a small-signal 2N2222 transistor had been used previously to switch on/off a 500mA relay. As a novice, I took all this as wisdom from my elders; that is, as a cookbook recipe. Now, making a second pass but still as a novice, I'm trying to understand why the MOSFET was chosen. There seem any number of "power" transistors, like the TIP31A, that could carry the required current. Some textbook suggested that the transistor loses voltage. Was the MOSFET chosen because it would maintain the 12VDC from drain to source? Or is there some obvious difference between relays and pumps that makes the MOSFET more attractive? All things being equal, transistors seem cheaper, less prone to ESD damage, and easier to acquire. From scratching my head over the textbooks, I'd like to ask one other question too, if I could, please. In the "before" picture, the books tell me the size of the R5 resistor is chosen relative to the minimum hfe (or beta, or DC current gain) of the transistor. But on the datasheets, the hfe never shows for the voltages I'm using, 5V or 12V. They'll show hfe for 100mA and 1V, they show for 1A and 4V, but never for 500mA at 12V. How do I do that conversion? Thanks very much. | |
| Not only does a MOSFET loose less voltage, it also doesn't require any gate current to turn on fully. Generally transistors require a base current of 1/10 of the load current to turn on fully. MOSFETs are normally only used at higher power levels which is why you don't see that many small ones. In the first example a MOSFET isn't really advantagous as the relay is only small. In the second example a MOSFET is more worthwhile as the load current is much greater and the op-amp (which can only supply 20mA at most) will struggle to fully saturate a transistor, unless it's a darlington.
| thanks fromt he lurkers club! | |
On Semiconductor's datasheet is a little more detailed than most. There's a hfe vs. Ic graph on page 3 that you can use as a reference. At room temperature and 500mA current going through the transistor and relay, it says you're looking at an hfe for about 50. But say that graph wasn't there. If that were the case, you have to take the data points they give you and do a non-linear regression to find the hfe values in between. There's also (very expensive) software that can reverse-engineer this for you. But yeah, it's definitely something the book don't tell you. | ||
MOSFETs (Metal Oxide Semiconductor FET) are the most common FETs and have a high impedance gate that looks like a small capacitor. Less common are JFETs (for Junction FET) which have a gate that looks like a reverse biased diode. CMOS circuits (for complementary MOS) uses both n-channel and p-channel MOSFETs in the same circuit to achieve high speed and minimize power consumption. | ||
| One of the reasons that MOSFETs are favored at higher power levels is the way they behave when they heat up and how that is better than a bipolar transistor. Since transistors are not ideal they get hot when passing a lot of current. When a bipolar transistor gets hot, its Vbe decreases (referred to as a negative temperature coefficient device) and in many biasing situations this encourages more collector current to flow which tends to add even more power dissipation and adds to heating the transistor even more. This increased heating builds on itself and can cause temperature to increase out of control, something we call thermal runaway, where the transistor breaks down. The MOSFET, on the other hand, has a positive temperature coefficient. That is, as it heats up, its drain impedance increases and this tends to decrease the current in typical circuits. So there is low risk of thermal runaway in the MOSFET unless it is configured as a constant current source. This is another reason the MOSFET is popular in power circuits. In the circuit in question, the amount of power dissipation in the transistor is low so this MOSFET advantage is not important.
__________________ RadioRon Last edited by RadioRon; 12th May 2008 at 06:46 PM. | |
http://en.wikipedia.org/wiki/Positiv...re_coefficient Lefty
__________________ Measurement changes behavior | ||
__________________ RadioRon | ||
| Never overlook the obvious - a 30A mosfet can be had for as little as £0.30 in single quantities while a relay + transistor will set you back a fair bit more than that. You can also use PWM to vary the speed of the motor with the MOSFET which you wouldn't be able to do with the Relay. Anyone else think the 1N4148 would be a little underrated to provide protection for a 500ma 12v motor though ? | |
Lefty
| Thanks for responses that are pretty clear, even to a beginner. For the 1N4148 vs. 1N4004 discussion, I'm again poring over the datasheets and wondering what's the critical characteristic for "underrated". Is it Io, Average Rectified Forward Current, which is 150mA for the 1N4148 and 1A for the 1N4004? If so, would any diode do, whose Io was greater than 500 mA? About the MOSFET. The pump motor says it will switch on at 8V (and run weakly), but it runs best at 12V. Did I hear that the MOSFET will allow all 12 volts will make it from the power supply through the pump? Please could someone show me how the output from the LM741 is limited to 20 mA? I was surprised that this circuit has no capacitors. But as I know so little, I didn't want to mess. Are they unnecessary here? If they would be useful, do I go with the rule of thumb "capacitor voltage should be twice the supply voltage" or, in this case, 25V? | |
Lefty
Mike. | ||
Lefty
Mike. | ||
| pic and mosfet interface | h.d | General Electronics Chat | 16 | 11th December 2007 09:18 PM |
| Questions from a beginner in electronics... | Shocks McTool | General Electronics Chat | 8 | 21st November 2005 03:01 AM |
| MOSFET Relay problem | guilio_2000 | General Electronics Chat | 16 | 10th August 2004 05:33 PM |
| Here is a list of semiconductor prefixes. | TPS | Datasheet/Parts Requests | 0 | 21st December 2003 08:24 PM |
| Identify Semiconductors by prefixes | mixos | Datasheet/Parts Requests | 0 | 10th December 2003 07:56 PM |
