| | #1 (permalink) |
| Experienced Member Join Date: Dec 2006
| Hey all! It has been a long time since I have posted anything. So I thought I would get back on. Anyway, I read about a hack to be able to see Infrared light on a USB webcam on hack a day. So I sucessfully completed the hack. But now I would like to build an IR emitter to place into the webcam body so as to use it as a night vision camera. So basically, I am looking for a simple, but yet powerful IR light circuit that can run off of the USB 5v. DC power running to the camera. Is there a simple way to achieve this? I used a stereo remote in a dark room with the cam, but obviously it sends short bursts, and I need it to be constantly on. Any help will be appreciated!! Thank you! |
| | #2 (permalink) |
| Experienced Member Join Date: Dec 2007 Location: Oregon, US
| http://www.digikey.com/scripts/dksea...name=1N6265-ND These are $1.60 each ($1.28 each if you buy 10). I'm not sure how much current can pass through USB, but these draw 100 mA. They have a wide beam angle (80 degrees). Hope that helps, -Mike |
| | #4 (permalink) |
| Experienced Member Join Date: Feb 2006 Location: Florida
| Picture of a camera I through together to watch for rats on my back porch. The B/W board camera was ultra cheap ($6, I think no lens, CS mount). You can get IR LEDs for much less the Digikey, 50 cents or less surplus. I'd suggest a narrower angle if you want some distance with the webcam. Too much IR up close might wash out the image (little bit of a problem with my carport camera). Should see how much current your camera needs from USB, before adding a bunch of those 100 mA LEDs, might add up quick... think you get about 350 ma out of a USB port. |
| | #5 (permalink) |
| New Member Join Date: Apr 2008
| I've played with this = much fun - take a look at a new $20 bill! also look at your striped tie. ANyway, more light = better picture and longer wavelength = less visible to rats (but I bet they see IR better than humans do!) but longer wavelength = decreased photo detection by CCD and poorer resoultion. So may I suggest, use a seperate light source - a nice gel cell motorcycle battery should give many hours of high current output and you could charge it during the day with a photocell! |
| | #6 (permalink) | |
Anyway, for the OP, I just want to share some of my experiences with IR illumination. I've built 5 spotlights so far. Will admit to stealing the PCB artwork for my last two, from the kit assembly instructions I found on the web. My first two are in the carport, of my own design, and a little too bright and wash out on light and reflective surfaces (faces). Could have just changed the resistors to tone them down a little, or add a resistor in series with the power supply, but I sealed the lights up with hot glue, and used staples to hand the cables. Just pointed them a little off to the sides instead... Guessing the OP's webcam is color with IR filter removed. Not sure how sensitive it is to IR. My B/Ws were meant for low light, and are very sensitive. | |
| | #7 (permalink) |
| New Member Join Date: May 2008
| Imnewtothis Check out: http://www.cs.cmu.edu/~johnny/projects/wii/ Johnny has hacked a Nitendo Wii Remote (Bluetooth IR Sensor & Tracker). There is a massive on line collaborative project on how to use and develop this system include VR tools and Interactive Whiteboards. Checkout the forum: http://www.wiimoteproject.com/ You will find a solution to your problem and some really cool places to take your new found knowledge. benpaddlejones Last edited by benpaddlejones; 10th May 2008 at 08:28 AM. |
| | #8 (permalink) | |
| Experienced Member Join Date: Oct 2006 Location: Australia
Thanks for the links, I'm going to have to try that out now
__________________ Spency. How many PC programs are developed with assembler? Then why use it with PIC's? PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net | |
| infrared emitter and sensor | mlois14 | General Electronics Chat | 9 | 10th May 2008 07:02 AM |
| Measuring the Speed of Light Using Infrared Pulses | Moneer81 | Electronic Projects Design/Ideas/Reviews | 11 | 11th March 2008 05:06 AM |
| Infrared Light sensing with PIC16F877 | emufambirwi | Micro Controllers | 1 | 12th October 2005 06:43 PM |
| Light control using infrared. | letsrelaythat | Electronic Projects Design/Ideas/Reviews | 11 | 25th August 2004 02:03 PM |
| n00b needs advice: Infrared Emitter and Receiver | Shion Uzuki | General Electronics Chat | 2 | 3rd June 2003 06:27 AM |
