Old 7th May 2008, 11:50 AM   (permalink)
Default TV Fuse Keeps Blowing
A surge tore my tv power supply fuse apart. I thought buying a new fuse will do the trick - it blew it as well. My troubleshooting took me farther to the Capacitor and the big guy said he was OK. The 4 diodes 2 were OK. So I was wondering whether the new 3A fuse I bought was too small?
I also series-ed the television with a 100W bulb, according to this site: http://www.repairfaq.org/REPAIR/F_smpsfaq.html a persistent problem in the PSU would make the bulb go very bright, mine didn't even light up at full load. My question what else could be the problem? Could I have wrongly connected something, switched polarity? I'm avoiding uprooting the regulator for the moment..
Everybody can but not everybody will.
aibelectronics is offline   Reply With Quote
Old 7th May 2008, 12:05 PM   (permalink)
The power supply is probably blown - a large mains surge could have taken the transistor and/or IC out - or it may just have failed?.
Old 7th May 2008, 12:41 PM   (permalink)
The series bulb test gave me the doubts, so I got a 5A fuse. I don't if that's too high? Curiously enough the manufacturers (Zaiko) didn't indicate a wattage/current rating for their television. The bulb didn't even light up!
Old 7th May 2008, 05:32 PM   (permalink)
I don't understand. Do you have the bulb connected with a good fuse in place and it doesn't light? Yet when you connect it without the bulb the fuse blows? That doesn't seem correct. If the fuse blows, then the bulb should light.
crutschow is offline   Reply With Quote
Old 8th May 2008, 01:03 PM   (permalink)
The transistor (a 2S4236) is off. It was short-circuited throughout. I got 2 new ones. When connected with series bulb the bulb went bright, reduced drastically then came up brightly again. I guess the Cap was charging at the time. The TV even came on although it would go off and come on again.
However on disconnecting the bulb and connecting directly to mains my 3.15A fuse blew. My transistor wasn't spared as well.
Now I've soldered a second transistor, but I'm yet to find the courage to connect direct to source again! Starts up with the bulb like before. What could be up? A weakened capacitor? Some fault elsewhere?
Need your i/p.
Old 8th May 2008, 03:09 PM   (permalink)
You need to replace every faulty component, blowing a second transistor may have damaged further components as well - a lot depends on the exact circuit, but a common cause is electrolytic capacitors drying out and going high ESR.
Error editted, thanks crutschow.
Old 8th May 2008, 03:23 PM   (permalink)
Sounds like it's not oscillating right or not at the right voltage. Try looking at the regulator. Check all the diodes in around the flyback.
Truthiness Monkeys : Obedience, Ignorance, Fear.
killivolt is online now   Reply With Quote
Old 9th May 2008, 04:12 AM   (permalink)
Originally Posted by Nigel Goodwin
but a common cause is electrolytic capacitors drying out and going low ESR.
Hate to be picky Nigel, (and I have a feeling you know this) but normally you want a low ESR (equivalent series resistance), the lower the better, especially for those caps used to filter switching regulator outputs. A resistance that goes low in a bad cap is the parallel (leakage) resistance.
Old 9th May 2008, 10:37 AM   (permalink)
Sorry, a typo
Obviously it's HIGH ESR that is bad!.
Old 16th May 2008, 04:47 PM   (permalink)
In a summary, there was another transistor in a darlington with the main power transistor. The capacitors were all OK. Changing the two transistors as well as the fuse did the trick. There's no satisfaction that beats the one derived from fixing a dead equipment...
Thermal fuse ? ClydeCrashKop Datasheet/Parts Requests 5 2nd September 2007 09:40 PM
is this a termal fuse or slow-blow type? KevinAlaska Datasheet/Parts Requests 9 27th July 2007 02:57 PM
amplifier Keeps blowing Fuses troubleshooting 101 walters General Electronics Chat 15 19th August 2005 07:51 PM
Fuse question. Lil_Guppy General Electronics Chat 18 7th May 2005 01:53 AM
Fuse blowing up MuLdEr General Electronics Chat 2 14th February 2005 10:37 AM
