| Notices |
| | (permalink (permalink)) |
| I'm having a problem with MUX in my circuit. It's a strange problem. When I use MM74C151, circuit works as it should be. But when I use SN74LS151 replacing the MM74C151, circuit doesn't work as before. What could be the problem? I don't think there's any problem in SN74LS151 because I have three of those. Plz help!
__________________ I'm here to learn from the EXPERTS! | |
It could be a logic level threshold or fanout problem. Please post you circuit diagram.
The 74LS151 is designed for a +5V supply. The easiest solution would be to use the 7805 for the logic supply. Add a low cost npn transistor and resistor to drive the relay, supply the relay with voltage that is input into the 7805. Is it possible that you could post a circuit, so that we can suggest a solution.? What power supply voltages do you have on the project.?
The absolute supply rating is +7V, so it should be OK.
| Can't solve the problem. Here's my schematic. In my schematic where it says 5V, I have used +5.9V.And when I use MM74C151 it works fine but 74LS151 doesn't do what it should! hELP ME OUT!
__________________ I'm here to learn from the EXPERTS! Last edited by ruzfactor; 10th May 2008 at 08:10 PM. | |
I dont see any schematic. I see it now.
I would say its the 741's thats the problem, powering them with a +5V rail, I suspect the outputs of the 741's do not goto thru the switching thresholds of the LS151's. Can you measure the 741 outputs [high and low] and tell us what they are.?
| A lousy old 741 opamp is not supposed to work when its supply is as low as only 5.9V. If it does work, its output low voltage is about +1.2V. The maximum allowed input low voltage for an old TTL IC like a 74LS151 is +0.8V so of course it won't work when fed from a 741 opamp. The maximum allowed input low voltage for the Cmos 74C151 is +1.77V so of course it works.
That lower voltage is the problem, its not a logic low for the 74LS. Using a CMOS ic could also give random problems. What other OPA's do you have.?
Do you have access to the LM393 dual compartor.? This would replace the 741 OPA compartors, use a 4K7 on the outputs of the LM393, a 1mA sink current should give a saturation voltage of < 0.5V.
| Keil C problem | sarang1_in | Micro Controllers | 3 | 27th February 2005 05:05 AM |
| Problem; Random pic performance | timothyjackson | Micro Controllers | 7 | 19th February 2005 06:19 PM |
| Big problem!! | zezito | Electronic Projects Design/Ideas/Reviews | 4 | 29th October 2004 02:05 AM |
| 12F675 Problem | brodin | Micro Controllers | 10 | 29th December 2003 09:40 PM |
| strange color camera problem | schrodingerscat | Electronic Projects Design/Ideas/Reviews | 5 | 4th October 2003 07:25 PM |
