Old 1st May 2008, 03:11 AM   (permalink)
Default Equivalent PNP-transistor
Hi All,
I am looking for the equivalent of a TOSHIBA-PNP transistor RN2221 with built in bias resistors.
The package is TO92. The RN2221 has two 1KOhm resistors built in.
Any info?
Thank you.
Hans
Boncuk is offline
Old 1st May 2008, 10:25 AM   (permalink)
They are normally called 'digital transistors', all you need is a PNP digital transistor - type doesn't really matter, it's just a switch.
Old 1st May 2008, 01:50 PM   (permalink)
Hi Nigel,
may be that applies in English speaking countries. At NXP (Philips) they just call them "resistor equipped bipolar transistors".
However I found a suitable substitute for the RN2221. The type name is PDTB113E (package SOT54, similar to TO92), just in case somebody else wants to save parts on a PCB.
Hans
Boncuk is offline
Old 1st May 2008, 11:31 PM   (permalink)
If you shop at http://www.ROHM.co.jp you would be looking for digital transistors.
mneary is offline
Old 2nd May 2008, 10:48 PM   (permalink)
Hi mneary,
thanks for the hint. Without detour the site's name is http://www.rohm.com. For Europe it is http://www.rohmeurope.com.
I signed up yesterday night and waiting for approval. (club card )
Hans
Boncuk is offline
Old 3rd May 2008, 11:21 PM   (permalink)
I'm sure there are lots of them. They're just designed to buffer microcontroller outputs for things like relays.
It'd be handy if you could get them in four pin packages, with a built-in freewheel diode so relays can be switched with no external components.
Screen name: Aloone_Jonez
Hero999 is offline
Old 4th May 2008, 02:46 PM   (permalink)
They are usually far too small for that, they are normally only low signal devices, inverting and switching data - you get them all over TV's, VCR's etc.
Old 4th May 2008, 03:47 PM   (permalink)
Most of them have a TO-92 package. They are available from 100mA to 800mA collector current, enough to control a relay.
Examples: RN2221 800mA, DTB113E 500mA
to hero999: They are available with free wheeling diodes as arrays of the "ULN"-family.
Hans
Boncuk is offline
Old 5th May 2008, 11:51 PM   (permalink)
Rohm makes devices they call "complex transistors", including some with both 100mA digital transistor and freewheeling diode. Look for EML17 and EML20. They are in 5-pin packages, outside dimensions 1.6 x 1.6 mm.
mneary is offline
transistor equivalent zavedur rahman Datasheet/Parts Requests 3 19th May 2008 06:22 AM
equivalent of transistor milann Datasheet/Parts Requests 2 2nd June 2005 10:34 PM
my transistor burned out h1061 and need equivalent zinalco Datasheet/Parts Requests 3 7th January 2004 10:18 AM
equivalent transistor for A104 & A144 benzy General Electronics Chat 1 25th October 2003 05:09 AM
transistor equivalent subzero349 Datasheet/Parts Requests 4 5th August 2003 04:52 AM
