Old 30th April 2008, 02:29 AM   (permalink)
Default How it works?
Pls see attached ,can anyone explain how R1 & Q1 contribute to this high current power supply?
wkyong is offline
Old 30th April 2008, 02:36 AM   (permalink)
THe resistor is making a feedback loop for Q1 so it is dropping the extra voltage across it the same way the LM is dropping extra voltage in order to produce a lower, regulated voltage. Q1 and R1 are like an amplifier that is in parallel with the LM to increase current output. A1 is using the LM's regulated voltage in own feedback loop to imitate and assist the LM in current output capability.
NO, that picture isn't me so don't bother asking if we can be friends.
dknguyen is offline
Old 30th April 2008, 02:52 AM   (permalink)
The transistor is turned off and the regulator regulates low load currents.
When the current in the load increases then it also increases in the regulator and when it causes 0.7V across the 3 ohms resistor (0.7V/3 ohms= 233mA) then the transistor turns on and passes any more current.
If the output is shorted then the current will be extremely high and the transistor will be destroyed. A second transistor can be added to limit the max current.
audioguru is offline
Old 3rd May 2008, 06:47 PM   (permalink)
You are not using the LM78xx to it's full potential change the resistor to 0.75hm: to work it a little harder and take some of the stain off the transistor. Of course, if you're using this for a high input-output voltage differential then stick with the 3hm: as the LM78xx limits the current to about 250mA at differentials over 15V.
The p
Screen name: Aloone_Jonez
Hero999 is offline
Is this Cicuits Works ? AboZakaria Alternative Energy 11 10th June 2008 09:25 AM
My button works like magic, I only have to hover my finger over it jimfraseruk Micro Controllers 31 13th August 2007 08:42 AM
How this circuit works fugrammer General Electronics Chat 15 25th October 2006 03:57 PM
Randomness of 16F84 program - sometimes works somtimes doesn FusionITR Micro Controllers 10 28th February 2006 10:06 AM
what works in the simulator does not work on hardware??? spyghost Micro Controllers 7 26th May 2004 12:15 PM
