Old 29th April 2008, 07:34 AM   (permalink)
Default H-bridge Problem
dear all;
i have power transistors (tip122 -npn- ) and (tip126 -pnp-) in order to make a high rating H-Bridge i tried to use the four npn transistors in one design and to use two npn and two pnp in another one but there allot of problems , the motor rotates in a very low speed and on of transistor burned how can i come over these problems without using a single H-Bridge chip .
thank you
ahmad-al3omar is offline
Old 29th April 2008, 07:40 AM   (permalink)
Originally Posted by ahmad-al3omar
dear all;
thank you
Post the design for 2*npn and 2*pnp version so that we can check the circuit.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 29th April 2008, 08:17 AM   (permalink)
Default my design
this is the siple circuit
Old 29th April 2008, 08:29 AM   (permalink)
Attachment 19002
The diagram shows -12V as the supply to the bridge, is that correct.? EDITED:
Also, what are the signal levels at 'A and B'.?
EDIT: If I magnify the drawing I can just see the +12V, in normal viewing it looks like a minus sign.!
Eric
PIC tutorials:
Old 29th April 2008, 08:39 AM   (permalink)
Your transistors would probably benefit by adding a schottky diode to their outputs. While it won't help any speed issues you may be having, it will more than likely extend their life.
positronicle is offline
Old 29th April 2008, 08:45 AM   (permalink)
the signal 5v with 20mA current and the motors operates at +12 volts and 1A current
Old 29th April 2008, 08:55 AM   (permalink)
When 'A' is high [+5v] the motor will only have about 3 or 4V across it.
Added protection diodes to the circuit.
EDIT: updated drawing showing some approximate voltages.
Eric
PIC tutorials:
Old 29th April 2008, 12:12 PM   (permalink)
You show each leg as a class B output stage, like in an amplifier. Classic H bridge designs have the pnp on the highside, and npn on the lowside. I would actually trash this whole design and go with mosfets. Use a p channel on the highside and n channel on the low side to avoid using a charge pump. You did not mention the amount of current needed.
"Everything that is done in the world is done by hope." -Martin Luther
"There are two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle."-Albert Einstein
Analog is offline
LCD problem Night Rider Micro Controllers 19 10th April 2008 06:24 PM
Problem of signal for an ECG with INA114 ninjasam Electronic Projects Design/Ideas/Reviews 4 28th January 2008 04:29 PM
JDM programmer problem krvavizmaj Micro Controllers 3 2nd October 2007 09:36 AM
Eprom write problem using PIC16F676 mathur2000 Micro Controllers 9 6th July 2007 07:27 AM
Strange problem tkvenki Micro Controllers 1 3rd May 2007 12:40 PM
