Old 27th April 2008, 06:20 PM   (permalink)
Originally Posted by ericgibbs
Hi Frosty,
Do you have a electronics/logic simulation program in your PC.?
Yes I got Multisim, Quartus II, and Xilinx...
I already tested the circuit in Multisim however I wanted to hear expert's opinion on this topic as I generally don't trust simulators...
"The people who cast the votes don't decide an election, the people who count the votes do."
-Joseph Stalin
Frosty_47 is offline
Old 27th April 2008, 06:25 PM   (permalink)
I agree, sims are just a guide, but they can highlight errors.
Looking at the MAX7400 datasheet says, Vin can be Vdd/2.
So a 3V input will drive it OK, if its powered from 5V..
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 27th April 2008, 06:42 PM   (permalink)
The MAX7400 is a Cmos filter IC. It needs to be clocked with a signal that is 100 times higher than its cutoff frequency by a Cmos square-wave or by its own internal oscillator. The clock signal must be with a low of 0.5V or less and a high of 4.5V or more.
The input signal might need an RC lowpass filter to remove high frequency harmonics that would cause aliasing with the oscillator. Your input square-wave might have harmonics that must be removed ahead of the filter IC. The input level to the filter IC can be any level up to about 4.8V p-p but signals lower than 1V p-p have higher distortion and noise at the output. The gain below the cuoff frequency is 1.0.
Why not use Cmos logic ICs to make a 5V p-p square-wave instead of old TTL that makes a square-wave around 3.4V p-p??
audioguru is offline
Old 27th April 2008, 06:55 PM   (permalink)
Because I am crazy thats why
Basically I want a 5V TTL to go into a MAX7400 that will output a nice 5Vpp Sine wave that I can further boost to 24Vrms with OPA445 (assuming I get one). The minimum High input Voltage for MAX7400 is VDD-0.5V which means it has to be at least 4.5V if VDD = 5V. Thus the typical output of 3.4V will not due for MAX7400 (please correct me If I am wrong)...
I'm not familiar with that Maxim part, but if it's supposed to be a logic input it will probably work?. Failing that a simple open collector buffer and a pullup resistor to 5V is all that's required.
I've just had a read of the datasheet, I would suggest you simply try it, I suspect it may be perfectly fine.
Old 27th April 2008, 08:34 PM   (permalink)
The input frequency of the square wave is variable (600Hz - 6Khz). What design of low pass filter can I use (if needed at all) for this aplication ?
-Joseph Stalin
Old 27th April 2008, 08:41 PM   (permalink)
A simple RC lowpass filter starts its rolloff at 1/5th its cutoff frequency. So 6kHz x 5= 30kHz. It won't have much effect on the harmonics of 600Hz.
Old 27th April 2008, 09:10 PM   (permalink)
Thank you for your help. With this info I can hopefully finish my AC motor control project. Personally I think I've gone way 2 far with this but than again, I learned something new doing it
Oh, and thanks for that CMOS IC suggestion, I was able to find variety of 40XX IC's that suite my needs so I won't be needing that blastted 741....
-Joseph Stalin
amp project andynerd General Electronics Chat 29 12th April 2008 04:24 PM
Questions on Thermistor Circuit bismark99 General Electronics Chat 14 1st April 2008 01:05 AM
Clamp output of op amp dazza000 Electronic Projects Design/Ideas/Reviews 21 9th November 2007 09:32 AM
741 - Comparator problems Nutmegzzzz Electronic Projects Design/Ideas/Reviews 3 30th September 2007 08:42 AM
PA Amp; noise reduction help CrazyOldGuy Electronic Projects Design/Ideas/Reviews 3 18th September 2007 05:46 PM
