The ROV sub thread has me thinking about relays CONTACTS and how they are rated. When it comes to analog I do not get much past ohms law.
The contacts carry power so I think of that as P = IV If that is correct a relay with contacts rated at 5A 24V could be used with 10A 12V. If I am still on the right track what is one to think when no voltage is given for the contacts? I know the voltage for the contacts are in regard to (also in regard to?) flash over between the poles. Or is it all to do with flash over and nothing about current? If so how can that be? Does P=IV not apply?
search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) |
I think you need to think about the two ratings as defining a "safe operating area" If there is a fixed contact resistance and you double the current the power will be quadrupled.
I would think that a local AND applies here and that you need to be at or below both ratings. Still I could be wrong, but that is how I've always interpreted those ratings.
We never have time to do it right; but we always have time to do it over. |
Contacts specs (current and voltage) should be looked at as seperate specifications and not as a composite power spec. Also if you check the spec on most relays they have different max current specs for AC Vs DC current. This is because AC can be more easily switched off as the AC voltage zero crossings help keep contact arcing down, where as DC is much harder on contacts at the same ratings. Not a good idea to utilize relay contacts at or near their rated maximum as contact life will be shortened. I would not go above 50% of ratings if reliablity is important.
Lefty
Measurement changes behavior Last edited by Leftyretro; 27th April 2008 at 12:29 AM. |
You need to do a search for "relay contact ratings", and read some of the hits. I found some very good info by doing this.
(permalink) | ||
Please do not slam the door on this with "google for it". There is a lot of information on the web and not all of it is good. The hope is that someone here could explain it or point to a web page that does.
The following is a "Danger Will Robinson" sort of thing. Quote:
hi 3v0,
This pdf is produced by a relay manufacturer, so it should be reliable. Hope it helps.
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 7th July 2008 at 11:23 AM. |
Thanks. It should be helpful.
I don't think you will find someone on this forum who knows more about this subject than the manufacturers of relays, and it is very likely you will get bad advice here. Last edited by Roff; 28th April 2008 at 12:25 AM. |
| Supplying Current Question | LiquidOrb24 | General Electronics Chat | 5 | 24th October 2007 06:45 AM |
| question about a "2 Channel RF Relay Control Board" | jax1492 | General Electronics Chat | 2 | 26th May 2005 09:02 PM |
| Relay Question | yukanti | General Electronics Chat | 3 | 13th March 2005 08:42 AM |
| Current Question | windozeuser | General Electronics Chat | 16 | 29th November 2003 06:55 PM |
| Controlling a Coin Hopper | Dirk the Daring | Electronic Projects Design/Ideas/Reviews | 1 | 28th August 2003 08:01 PM |
