Hello I am a very, very, very non-electronic person, so I thought I could do a simple task of making a LED circuit, but I guess I was wrong. I am running this off of a 13.8V source, theres 4 blue LEDS (3.2V ea), and I have a 1/8 watt 56 ohm resistor. By all accounts this should light up I suppose but it didn't, the LEDs all were working and I can assume the resistor was as well, but when I hooked it up, nada. I assume the problem lies with my soldering since I am no expert in that area. Any ideas on how to fix this would be great! Thanks! Pics of my circuit: http://img509.imageshack.us/img509/4724/elecgu0.jpg http://img509.imageshack.us/img509/1036/elec2lg2.jpg | |
By the looks of the second picture, absolutely everything is soldered together. That's got to be the biggest solder short I've ever seen.
hi benji. Post the circuit diagram and a photo of the soldered side of the pcb.
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ | |
| | #4 | |
so the four LED's = 256mW! and the resistor = 20mW! So i would assume it would work! make sure that the LED's are in series correctly, meaning that the +(anode) and - (cathode) are not touching together! Last edited by shaneshane1; 26th April 2008 at 12:47 PM. | ||
Yes, it looks like you've soldered all the connections together, to make one join. Other than that, the lamps are all the same way round, and all the parts are in series, its just that they need to be connected individually, with a solder join for each junction. Its not far off correct, just a bit of practice. Oh, and dont have the copper conductor running along them in a line, try to have a seperate bit of copper for each join. Best of luck with it, John
__________________ ************************************************** *************** | |
| | #6 |
Ok so I resoldered everything, the blue lines are the solder, the L+ L- are the LED's. + and - are the source and ground. Still doesnt work. Did I do it wrong again? http://img169.imageshack.us/img169/2756/ledtr3.jpg | |
| | #7 | |
Reverse the two LEDs, whose connections I've circled in yellow. | ||
| circuit, working |
| Circuit functioning very strange. Why? | Cyclone | Electronic Projects Design/Ideas/Reviews | 13 | 19th February 2009 07:27 AM |
| Led cyclic dimmer/controller circuit? | yel-low | Electronic Projects Design/Ideas/Reviews | 13 | 9th August 2004 05:00 PM |
| Circuit not working... | brentonw2004 | Electronic Projects Design/Ideas/Reviews | 9 | 2nd February 2004 05:46 PM |
| Telephone CutBox circuit help | Qix | Electronic Projects Design/Ideas/Reviews | 8 | 28th January 2004 03:17 AM |
| On-time delay circuit using LM555 | mozikluv | Electronic Projects Design/Ideas/Reviews | 9 | 24th October 2003 02:45 AM |
