| Hi have a 16f628a pic going to a uln2003a that controls 3 dpdt relays relay 1 controls fwd / back motor1 relay 2 controls fwd / back motor2 relay 3 is to control which motor to control etc... as in picture attached eg: turn relay 3 on and relay 1 on and motor 1 turns fwd i could do it with relay 1 and relay2 and 2 spst relays but i have only these 3 relays any help???? MOD i did post this in a similar thread but it was better to start a new thread | |
| You can use the third relay to control either of the supplies (Vdd or Vss) of the other two.
__________________ Superman returns.. | |
| problem is that relays are now on board (silly me) but will that work if relay3 is dpdt as there is no off postion? iam blank here lol any easier way | |
| i think i can remember a way with a common return and using a diode but cant remember correctly any ideas? | |
| Since you're using relay 3 to select either relay 1 or relay 2, either SPDT or DPDT will work. A diode is used to protect the transistor that switch the coil.
| thanks for reply iam using a uln2003a with diodes in but i was thinking there was a way to use a diode to reduce wiring for forward and reverse cicuits an old model railway trick but i a cant remember now anyway is posible to have a diagram/instuctions of how relay3 could control relay1 or 2 apart from the vss vdd thank you | |
| Relay 3 could be used for direction control, or as a pulser as in a blender motor or pool pump. It can also be used to feed the two existing relays, or a third motor. | |
| Question on running a relay | bryan1 | Electronic Projects Design/Ideas/Reviews | 9 | 21st May 2008 09:36 AM |
| Relay Question | yukanti | General Electronics Chat | 3 | 13th March 2005 09:42 AM |
| Pic to Transistor to Relay, Amperage handeling question | iso9001 | General Electronics Chat | 21 | 1st July 2004 07:14 AM |
| Simple relay question.. | Swifty | Electronic Projects Design/Ideas/Reviews | 11 | 10th February 2004 05:31 AM |
| Relay Question....... | Shocky | Electronic Projects Design/Ideas/Reviews | 8 | 23rd November 2003 09:43 PM |
