| How do these things work? From what I'm reading it appears tha you can get say 11.7V output from a 12V source at 1A -> is this correct? How does it work if you need 1.7V across the transistor minimum? I'm considering using this as a voltage follower in place of a power transistor as I could get a higher output voltage. [I'm trying to make a fan speed controller buffer to handle multiple fans on a single controller line (eg there are 3 fans on my PC watercooling radiator) but I want to be able to get as close to 12V as possible for max speed when things get hot. Pulse width modulation (with 3 lead fans) makes the tach signal worthless so can't go that way btw] | |
| They use a different topology than the standard NPN pass transistor regulators (like LM317s and 7805s). It probably uses a single P type FET as the pass transistor. | |
| hi, This was recently posted by a member. 'thespeakerguy' Explains standard Vregs and LDO.
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 7th July 2008 at 12:24 PM. | |
| actually that was me | |
| | (permalink) | ||
I did post the credits naming you.. Useful pdf.
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ | |||
| Thanks! I really liked that tutorial. I was just wondering about the physics of the gating etc as to how the PNP can turn on with such a small voltage drop. Sometimes I can understand such explanations like the basics of how transistors work, so I was just wondering what is different about this configuration. Just curious. | |
| If you use an n-channel MOSFET and a small boost converter so you can drive the gate at a higher voltage than the supply, you can get a very low drop out voltage. It's a wonder that some ICs don't use this technique. There could be an on-chip voltage doubler so all you need to do is add a couple of ceramic capacitors to give an ultra low dropout regulator.
| Question about low voltage relays | wrybread | General Electronics Chat | 6 | 27th April 2008 09:13 AM |
| low voltage drop out circuit | zener | Electronic Projects Design/Ideas/Reviews | 8 | 22nd April 2008 01:27 PM |
| Speedometer | Kiko | Micro Controllers | 131 | 29th November 2007 06:33 PM |
| LDO Regulators and low voltage PICs | Stellarcore | General Electronics Chat | 5 | 26th July 2007 03:50 AM |
| Voltage Regulators - How do they know...? | grrr_arrghh | General Electronics Chat | 3 | 25th May 2004 03:22 PM |
