Old 23rd April 2008, 12:53 PM   (permalink)
Lightbulb Re: Voltage Comporator
Hi, im trying to build an eletronic system which autmatically detects a clooged heat exchanger. In order to do this i need to use two thermocouples which would measure the temperature, in tems of voltage, at teh intake and out take of teh heat exchange. I need some sort of voltage comparator which measures the difference in voltage between the two thermocoupples. Someone told me to use a voltage comparator circuit, but from what i see it is very limited to my use. Is there any type of circuit that can measure the difference between two voltages and give me a voltage that is proportional to this difference. I would greatly apprecaite anyones help in this matter as im am more oriened toward refrigeration.
Kris
sullie is offline
Old 23rd April 2008, 04:40 PM   (permalink)
Unless you understand electronics, I recommend buying a temperature readout that can do what you need such as this http://www.omega.com/ppt/pptsc.asp?r...300&Nav=temm08 or http://www.omega.com/ppt/pptsc.asp?ref=DP26&Nav=temm03 from Omega. They can display the temperature difference between two temperature sensor inputs and can sound an alarm when a limit is reached.
crutschow is offline
Old 23rd April 2008, 04:56 PM   (permalink)
I've used some of this Omega stuff - works great and a great company.
What output are you looking for - binary as in clogged or not clogged? Digital or analog voltage proportional to temperature difference? You can use a comparator fine with a trimpot for calibration if you or another knowledgeable person can fiddle with it and recalibrate each time you replace the thermocouples but if you are looking for a more modular approach that is simple to operate you will be time and money ahead going with the Omega stuff.
walshlg is offline
Old 23rd April 2008, 06:43 PM   (permalink)
I think an op amp used differential amp or comparator would work.
electronic spark is offline
Voltage ElectroMaster Electronic Theory 44 8th August 2007 06:35 PM
Silly transistor question, Voltage to the base nuttaphong191 Electronic Projects Design/Ideas/Reviews 1 25th May 2007 04:59 PM
boost converter overshoot / undershoot justDIY General Electronics Chat 17 21st December 2006 05:50 PM
Voltage Clamp ThirtyTwo General Electronics Chat 41 11th August 2006 05:05 PM
I am not getting ripple voltage at the output dar2525 General Electronics Chat 3 14th July 2005 03:21 PM
