| Hi folks, I would like to know how the pickup on a strobe gun works. Strobe gun = a device you use when setting the ignition timing on (old?) car engines. You place a pickup on the wire to the spark plug, and the strobe flashes everytime a spark is fired. I would like to know how the pickup can sense the high voltage going through the sparkplug wire - if possible, I would like to make my own. I hope someone can help. Thanks. Regards, Futterama | |
| It likely picks up a signal from the capacitance between the wire and the pickup. It doesn't take much capacitance to get a useable signal from the high voltage spark. If you experiment with coupling this signal into a circuit, be sure you limit the signal amplitude with zener diodes to avoid zapping the circuit. | |
How is capacitance picked up from the sparkplug wire? I have no idea how this is done. A simple schematic would be great if you have one. | ||
| Simply with a wire wrapped around the HT lead, or (more professionally) a spring clip (such as a clothes peg) with a metal plate on one side. | |
How do I then measure the capacitance so I can get a signal into a PIC? Do I need some kind of capacitance sensor chip? Or will there be generated a voltage on the plate with respect to ground? | ||
| you should read carefully what is said in a reply. Crutschow suggested you should limit the signal using a zener diode in order not to zap your circuit. Even a layman would think that there is voltage involved. RTFA! Boncuk | |
Also, please don't talk down to me because you know more of this stuff than I do. | ||
| Project: Strobe Light | ElectroMaster | Electronic Projects | 19 | 2nd November 2008 01:38 AM |
| Will this work? | MagnumForce | General Electronics Chat | 7 | 11th November 2007 01:12 PM |
| Necessity of "photoflash" caps for strobe? | Oznog | Electronic Projects Design/Ideas/Reviews | 6 | 22nd September 2005 12:13 AM |
| why doesnt it work | Emantra | General Electronics Chat | 4 | 20th September 2005 03:59 PM |
| House Electrics and how they work | ThermalRunaway | General Electronics Chat | 20 | 20th July 2005 11:53 PM |
