Old 22nd April 2008, 09:49 PM   (permalink)
Default Can this be done with the 555 ?
I would like to build a circiut, that would eg. put out a signal (turn on a device) with a 24 hour delay, and repeat it every 24 hour. (from when it was powered on)
Is this something the 555 IC will be able of? if yes, have any suggestions for a circuit?
If no - how could it be done?
TCDK is offline
Old 22nd April 2008, 09:58 PM   (permalink)
How accurate does this timing need to be? I think 24 hours is very close to, or beyond the limit of that a 555 timer will allow (due to capacitor leakage and tolerances and things like that).
You could make a simple PIC circuit with a very slow oscillator and store the counts in a massive register to count to 24 hours. THat would be very, very accurate. At 26MHz frequency, a 39-bit counter is enough to track 24 hours. You'd basically have to link together a giant series of integer variables together in memory since 8-bit MCUs don't have large enough counter registers that periodically get updated by a timer (a dsPIC timer counter can do this though if you use the 32-bit timer and a 256:1 prescaler, it can actually go up to 48 hours like this on a clock of 6.5MHZ x4 PLL).
Do you need the signal to go HI for 24 hours and then go LO for 24 hours? Or to pulse HI momentarily and then go LO, and then do so again 24 hours later?
You could also hack an alarm clock or stopwatch or something.
NO, that picture isn't me so don't bother asking if we can be friends.
dknguyen is offline
Old 22nd April 2008, 10:59 PM   (permalink)
If I were doing it I'd use a small PIC like the 12F629.
32,768Hz watch crystal on TMR1 (low power and wake up from sleep every 8 sec to update the time), latching relay (zero power once latched) and a battery. Should run for ages.
If you've got AC available then just tap into the 50/60 Hz signal for the timebase, use a PWM channel for the relay (assuming it's not latching) and there you go.
Bill
Smart Kits build Smart People
Old 23rd April 2008, 02:01 AM   (permalink)
I think Harris had a better timer chip back in the day (do not recall but maybe google for it). The lm555 I would not count on for a long delay.
If you go with a PIC or AVR you will need to get a programmer, write a program, etc.
mramos1 is offline
Old 23rd April 2008, 04:05 AM   (permalink)
Either I'm not fathoming the original description or ....
What's the matter with a simple $9.95 plug-in, synchronous-clock-driven timer?
Dean
R.I.P.
Dean Huster is offline
Old 23rd April 2008, 09:12 AM   (permalink)
Actually very accurate.
It should go "lo" for 24 hours, then give a signal (hi) on a variable time (eg. 30sec) and then go "lo" again.
TCDK is offline
Old 23rd April 2008, 09:13 AM   (permalink)
Dean
It's not half as fun.. And then it should be build in to a cabinet.
TCDK is offline
Old 23rd April 2008, 09:27 AM   (permalink)
Yeah, go for a PIC. Use a 32.768 quartz oscillator as the clock (probably the slowest oscillator you can get and definately the most accurate as that frequency and kind are used in RTCs). You'll probably need to use the secondary oscillator pins on the PIC rather than the regular (higher speed) oscillator pins. You don't need that fast oscillator anyways.
And then yeah, really easy code after that. Set up the clock and a timer interrupt.
dknguyen is offline
Old 23rd April 2008, 09:29 AM   (permalink)
hi TCDK,
Use a PIC, timer1, an opto detector for the mains half cycle [50 or 60Hz], using the low side of the mains transformer to drive the opto-detector in order to give the mains frequency output pulse to drive the PIC timer input.
Also look at the HEF4060 i/c
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 23rd April 2008, 10:00 AM   (permalink)
I will start buying this PIC programmer:
http://www.talkingelectronics.com/pr...-01-Intro.html
This is my very first PIC project - wonder if any of you knows a site or something, where I can see other 12F629 projects.
TCDK is offline
Old 23rd April 2008, 10:04 AM   (permalink)
If this is a one time thing you could use a PICAXE and safe yourself the cost of development tools.
http://www.rev-ed.co.uk/picaxe/
dknguyen is offline
Old 23rd April 2008, 10:17 AM   (permalink)
Loads of 'em
Here's a link that links other µ controllers.
http://www.tinaja.com/pic500.html
Brian218 is offline
Old 23rd April 2008, 10:29 AM   (permalink)
Originally Posted by Brian218
Loads of 'em
Hmm most of the links at that page, dosen't work.
TCDK is offline
Old 23rd April 2008, 10:53 AM   (permalink)
Found this one.
Looks simple for me.
Instead of the relay, I will put in a 555 timer, that will allow me to adjust the "HI" time.
TCDK is offline
Old 23rd April 2008, 11:09 AM   (permalink)
link would do it much easyer ´
http://uk.geocities.com/ronj_1217/c4060.html
TCDK is offline
Manually/Automatically Sequencing LED's with 555 and 4017 Vespian Electronic Projects Design/Ideas/Reviews 7 29th March 2008 11:56 AM
555 timer help thekyguy11 Electronic Projects Design/Ideas/Reviews 22 22nd January 2008 10:55 PM
555 timer traffic light cb4 Electronic Projects Design/Ideas/Reviews 9 12th December 2007 08:53 AM
Anyone experimented with minimum pulse with 555? chadj2 General Electronics Chat 4 12th October 2007 02:19 AM
555 Alarm! Krumlink General Electronics Chat 4 6th October 2007 11:47 PM
