Old 21st April 2008, 01:08 AM   (permalink)
Default alalog VU meter
i want to make a VU meter i think i can use the bargraph display driver any ideas
i dont really have something in mind i was hoping that you guys knew somethings on the topic
david d
new fav. band scary kids scaring kids
davidbball13 is offline
Old 21st April 2008, 02:36 AM   (permalink)
The LM3914 is a linear voltmeter and makes a poor VU meter.
There is the LM3916 IC which drives up to 10 LEDs in various sized steps as a VU meter.
There is the LM3915 which also drives up to 10 LEDs in doubling or halving of power steps as a VU meter.
The datasheet for the LM3915 shows a few "peak detector" circuits that hold the peak reading for a moment which is long enough for it to be seen. Without a peak detector then a bargraph is a blur and a moving dot is a dim blur.
I have a Sound Level Indicator project. It uses an LM3915 driving 20 bright LEDs in 10 steps that have a dimming pot. It has a peak detector circuit. I added 20dB worth of automatic gain control so that it displays a pin dropped on the floor of the next room if there is no other sounds and if I hold my breath, and it clearly shows loud music. Therefore its range in levels is 50dB.
It has a rechargeable 9V battery (actually 7.2V) plus a wall-wart power supply.
http://www.electronics-lab.com/proje...009/index.html
audioguru is offline
Old 21st April 2008, 08:31 PM   (permalink)
David - I have a bunch of small VU meters that appear to behave as if they have a logarithmic response built in. I am old enough to remember - but can't for some reason - if I am correct that many VU meters were constructed this way - so that that an otherwise linear signal does not need to be conditioned to get the log (I think that's what's needed) response. If I am correct all you will need to do is procure a VU meter and consider how you might adapt the available input to the range of the meter.
There are a number of ways to take a surplus or discarded meter and determine it's characteristics. You ought to be able to find that via google or in electronics references.
stevez
stevez is offline
Any ham radio folks here willing to humor some dumb questions? Andy1845c Chit-Chat 17 5th January 2008 08:41 PM
Simple Field Strength Meter ElectroMaster Electronic Projects 8 14th June 2007 02:07 PM
Meter Data Sheets Overclocked Datasheet/Parts Requests 4 12th June 2006 11:26 PM
Panel meter, analog VS digital Johnson777717 General Electronics Chat 7 23rd June 2004 12:33 AM
Specifications Applied Caltech General Electronics Chat 1 25th December 2003 06:00 PM
